bumonskateboard6 Posted December 20, 2010 Report Share Posted December 20, 2010 Also everything is in the trunk so it's only 3ft of cable from the amp to the battery. I am using the factory radio with a hi/lo filter. Could that be the problem? Hi/Lo filters if they aren't powered take so much gain on the amp to get a strong voltage signal to the amp. Try one of these for a cleaner signal. http://www.rockfordfosgate.com/products/product_details.asp?cat_id=1&series_id=49&family_id=51&item_id=111123&locale=en_US&p_status= Quote Current Systems: 2011 BMW 335i Hertz HDP1 DC LVL3 12" Full Carbon Fiber 2002 Acura TlKenwood DNX9980HD2 DCLVL4 12" Subs with LVL5 Parts D.7 CoilsDC 3.5kHertz HSK-165 up front HCX-165 RearHertz HDP4 AmpDC Power Engineering 260 Amp AltBig 3 and amp powered with KNU 1/0XS Power D2400 Up Front i pulled out my dick in class many of times and had it shown. get over it bitch...stupid open legged hairy beavered bitch... going over rms = smaller box, under rms = bigger box... Low voltage doesn't blow amps. That's a myth. A router that does the sub holes makes rounded edges also? Link to comment Share on other sites More sharing options...
Ds5381 Posted December 20, 2010 Author Report Share Posted December 20, 2010 Yeah it's not powered. I'll try a new ground first then if that doesn't work I guess I'll go that route. Thanks Quote Link to comment Share on other sites More sharing options...
Superjay Posted December 20, 2010 Report Share Posted December 20, 2010 your LOC should have gain control on it. adjust it down. Quote Principal JTech Consulting - Leader in 12-Volt Training and Product PlanningIt's not about how much power you have, but how well you use it Link to comment Share on other sites More sharing options...
Ds5381 Posted December 20, 2010 Author Report Share Posted December 20, 2010 Haha everything I sealed. I'll have to take half my car apart to get to it. Quote Link to comment Share on other sites More sharing options...
Superjay Posted December 20, 2010 Report Share Posted December 20, 2010 well, guess you should have thought of that. with modern head units putting out 11-15 watts per channel those gains should be about a quarter of the way up...most come cranked to max from the factory. or worse...not matched Quote Principal JTech Consulting - Leader in 12-Volt Training and Product PlanningIt's not about how much power you have, but how well you use it Link to comment Share on other sites More sharing options...
Ds5381 Posted December 20, 2010 Author Report Share Posted December 20, 2010 I didn't do the install. I kinda wish I did now. I had a local shop do it. They are very reputable so I hope it was set rite. Quote Link to comment Share on other sites More sharing options...
Ds5381 Posted December 20, 2010 Author Report Share Posted December 20, 2010 I believe it's off the factory sub. Quote Link to comment Share on other sites More sharing options...
Superjay Posted December 20, 2010 Report Share Posted December 20, 2010 even pros forget about it. they usually forget about it, but since you had it done at a shop take it back there, explain the issue and ask them to take care of it. If they find that it's something they didn't do, then pay them for their time (probably $20 or so) for troubleshooting it, and go home and fix it, or pay them to fix it. Quote Principal JTech Consulting - Leader in 12-Volt Training and Product PlanningIt's not about how much power you have, but how well you use it Link to comment Share on other sites More sharing options...
Ds5381 Posted December 20, 2010 Author Report Share Posted December 20, 2010 (edited) I used to do all this myself I want to get back into doin my own installs. I should post pics of some of my old installs. I'm not a noob just been out of the game for a while lol Edited December 20, 2010 by Ds5381 Quote Link to comment Share on other sites More sharing options...
