2 18" DC lvl 5's 6KW of Sundown in a VW Lupo!
OP, im running a stetsom 7k2d on 4 kinetik 2400s, a 1400 up front, and a 200a alt.. and its not enough, with in 1 min full tilt i can be sitting at 11.2v.... if you can fit 2 300a alts I would go that route
The DC Integra 3 18s to 6 15 build log
Team_DC-Derrick's Youtube
Team DC Audio
where theres a will theres a wall.......
I just realized Steve has reach Voldemort status, over on JP's site he is the one who will not be named....."We dont speak his name over here, fearing it will destroy us" LOL not even in hush tones
no man hes only running 4 1500. I don't have a ton of voltage drop. Wide open on a 30 sec run. I go from 14.4 to 13.3 or 13 flat. I run in Streetspl so ea run is on music. On brups it drops less. Because my brup only last 5-10 sec anyway. I played around with a 2 3k in my car. Thats when I run into voltage drops into the 10's
1993 Mazda Mx-3
Subs: 2 18" DC Audio Lvl 4 D.7
Highs amp: Sundown SAX-100.4
Sub amp: Sundown SAZ-3000D
Electrical:Kinetik 1200 under hood, 2-Kinetik 2400 rear
All 1/0 KnuKonceptz Wire Power/Ground, Big 3, 8Ga Speaker Wire, KnuKonceptz Karma RCA's
Dampening: 120sqft 80Mil Thick Sound Destroyer Mat
Goal: 150 DB 149.9 Street Bass
so your telling me 4 1500s dont = 2 3ks.....
did you JUST say that?
because thats how i read it... you said hes fine hes only running 4 1500s, but YOU had issues with 2 3ks....
Team DC Audio
hes not gonna give it up. the point were trying to make is he is trying to run 6k which is the under rated power. The amps will do more like 7k. And hes trying to do it off a single 180 amp alt. Thats a big NO NO lol
2011 Subaru WRX
Rockford Fosgate T1000-4AD
(2) Sets of Rockford Fosgate T3 6.5 Components
In the works:
Rockford Fosgate T2500-1bdcp
(2)DC Audio 12" XLM2
It's the biggest I can fit on my car without custom brakets and alternators.... if u have problems ill change it, the car is only a 1.4tdi so adding stupid amounts of alts will lead to no power. Been told ill be fine with the power I have as there are no big alt suppliers in the UK.
that was my point, im running a 7k amp on a similar electrical system, and i have massive voltage drop
Team DC Audio
no that not what I meant. What i'm saying is that 180amp alt(asumming it putting out about 90-95 amps at idle)and with 600ah of battery power he could be fine powering 4 saz 1500. I know a car powering 2 SAZ-4500 (straped @ 1 ohm) on 2 2400 with no problem. And I had problem with 2 3k's because I have a smaller alt and half the battery power that this person is going to be using.
1993 Mazda Mx-3
Im just sayin, i have 572 AH worth of batts in my car, right around the same number the OP has, and I have similar power wise, on paper atleast... and i have a DC 180a alt that does over 200....
i have massive voltage drop... down to the 11s...
if you dont care about voltage drop thats fine... but im just trying to tell you since we have similar setups for power/electrical...
Team DC Audio
As I say if I have voltage problems ill change alternators.... there are cars in the uk using similar power as me with similar supply and they have no problems. For example, the loudest street basser car in the UK is using 16k with 2 210a alts and 9 shuriken bt100 batteries, I've personally sat in the car at full tilt and watch the voltage not drop below 14v!
