C.Sanchez.A Posted December 21, 2010 Author Report Share Posted December 21, 2010 It has level inputs, use those. No need for a converter. Can you explain? I haven't looked at my amp for months and I haven't looked at the car at all yet. Quote Click Links To View Build Logs 1994 - Mazda B3000 (Daily/Toy/Show) 2002 - Mazda Protege (Daily) 1995 - Hyundai Accent (R.I.P.) 1984 - Bronco II (Restoration Project) Youtube Channel Link to comment Share on other sites More sharing options...
C.Sanchez.A Posted December 21, 2010 Author Report Share Posted December 21, 2010 It has level inputs, use those. No need for a converter. Can you explain? I haven't looked at my amp for months and I haven't looked at the car at all yet. Did a little research and came up with. "Attach" another wire to one set of the speaker wires and then connect it to the high level impute on the amp. Quote Click Links To View Build Logs 1994 - Mazda B3000 (Daily/Toy/Show) 2002 - Mazda Protege (Daily) 1995 - Hyundai Accent (R.I.P.) 1984 - Bronco II (Restoration Project) Youtube Channel Link to comment Share on other sites More sharing options...
Rockbrook Posted December 21, 2010 Report Share Posted December 21, 2010 It has level inputs, use those. No need for a converter. never heard of this, please elaborate Quote Link to comment Share on other sites More sharing options...
C.Sanchez.A Posted December 21, 2010 Author Report Share Posted December 21, 2010 Turns out the amp I have is the Alpine MRP-F300 4 channel - 1 (I got it broken). It's not the perfect combination but it was free. Quote Click Links To View Build Logs 1994 - Mazda B3000 (Daily/Toy/Show) 2002 - Mazda Protege (Daily) 1995 - Hyundai Accent (R.I.P.) 1984 - Bronco II (Restoration Project) Youtube Channel Link to comment Share on other sites More sharing options...
MrSkippyJ Posted December 21, 2010 Report Share Posted December 21, 2010 (edited) Can you explain? I haven't looked at my amp for months and I haven't looked at the car at all yet. never heard of this, please elaborate High level (sometimes called speaker level) inputs are for amplified signals. RCA (low level) inputs are not amplified. The speaker outputs on the back of a radio are amplified so you need either a converter that converts them to a low level signal or inputs on the amplifier that are designed to accept an amplified signal. Turns out the amp I have is the Alpine MRP-F300 4 channel - 1 (I got it broken). It's not the perfect combination but it was free. Looks like that one also has the high level inputs, so you are still good to go Edited December 21, 2010 by shkibbybop Quote F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69 Link to comment Share on other sites More sharing options...
C.Sanchez.A Posted December 21, 2010 Author Report Share Posted December 21, 2010 Turns out the amp I have is the Alpine MRP-F300 4 channel - 1 (I got it broken). It's not the perfect combination but it was free. Looks like that one also has the high level inputs, so you are still good to go Sweet, that means I can install the sub right away. Quote Click Links To View Build Logs 1994 - Mazda B3000 (Daily/Toy/Show) 2002 - Mazda Protege (Daily) 1995 - Hyundai Accent (R.I.P.) 1984 - Bronco II (Restoration Project) Youtube Channel Link to comment Share on other sites More sharing options...
