Time to bring the pain
bigshane90
Lulz in this fucking thread.
I play 28hz until 10 Volts ..... That makes me a n00b?
Oh I don't use fuses in my personal vehicle as well ... Does that mean I'm
a noob? I've strapped my amps @ .5 .. An even at .25
Maybe I should strap at .175?
Your point is what.
I
Shut up
Because a keyboard commando says so right.
When amps have no internal fusing you fuse the wire to not only protect the wire but the amp as well so you were half right. Been doing this for a while and running small fuses wont cause a amp to let the magic smoke out as previously stated. If the guy who said that honestly thinks it will he is very misinformed and needs to do a little more research before giving advice. If I don't know omething I will tell you and do research and find the answer before spreading misinformation.
I love it question my credentials. OP do what you want. Ive never said anything about fuses being too small causing the amp to smoke. Im assuming your buddies with the OP based on location as well. probably members of the same club. Tell you what since I'm so misinformed go ahead and prove what I've said wrong.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
yeah you didn't say the fuses would smoke the amps, you said that the fuses won't handle the 1000amps that the amps will do at .5.
And in return the amp may not handle the .5 and smoke.
Rest In Peace mother.
January 22, 1955 - February 14, 2013
http://www.stevemeadedesigns.com/board/user/35351-megrch/
N
Well please tell me what you meant then as you keep talking about the fusing then saying show me the vid of the smoke I am all ears.
All I can say is both amps have been ran at .5 before for extended amounts of time no issue and with a single 80amp fuse for a while they will be just fine at 1 ohm strapped since we have already done extended amounts of testing.
All I can say is both amps have been ran at .5 before for extended amounts of time no issue and.with a single 80
amp anl for a while they will be just fine at 1 ohm strapped since we have already done extended amounts of testing.
You ran the pair of an 80 amp fuse?
Are you sure you wasn't running it at like 12 ohms?
2006 F-150
XS Power
4 DC 3.5kw
Team DC
Team S.P.L.
Lot of Audio Technix and 1/0
DC Audio Dealer
American Bass Dealer
XS Power Dealer
Audio Technix Dealer
Can't that amp pull more than 3** amps at 1 ohm?
No we ran a single amp off that fusing so 160 on the pair would work and the amp was at .5 and don't give me that rise talk as in a daily application music is dynamic and rise didn't come into play.
One amp at .5 on single 80 two amps strapped at 2 on 150 both amps at 2 will blow a 100 amp fuse after two or 3 burps
95 f150 xlt
Dc lvl 4 xl 18"
Aq3500 at .5
149.7 on music
2010 meca as3 world champ
2010 meca as3 Ky state record holder and ky state champ
149.7 drivers headrest with two 80 amp anl fuses amps strapped at two ohm one ohm per amp I run those fuses daily they don't blow I've had the same fuses in since September
95 f150 xlt
Dc lvl 4 xl 18"
Aq3500 at .5
149.7 on music
