nickportonova Posted December 27, 2010 Report Posted December 27, 2010 would it be ok to use a 600 rms sub hooked up to a 200 rms amp? it would only be for a few days though.
__d_a_v_i_d__ Posted December 27, 2010 Report Posted December 27, 2010 yes. Chevy Impala Shocker Sigs / TC Sounds 12s Sundown NS-1 | SAX 100.4 Sundown Neos | Dayton Audio Neos ETCCC ETCCC ETCCC My YouTube ---- Subcribe!!
thecityxignites Posted December 27, 2010 Report Posted December 27, 2010 yeah, it would work fine, the sub would just be underpowered. also, make sure that you have your gain set right, preferably with an o-scope. even though you're only running 1/3 of the sub's rms, if its clipped/dirty power, you can still blow your woofer. 2001 chevy cavalier Rebuild in progress what happens when your CD player skips and you accidentally drop a 22 hz sine bomb at an unholy volume on 7-8 year old subs? Mechanical failure floppy sub knockage on at least 2. well...as i see the level 6 is compared to a lamborghini.....but a corvette? i was thinking more like a chevy volt. its cute and new and "hip", but i would just rather stick my dick in a blender.........
hdorre Posted December 27, 2010 Report Posted December 27, 2010 yeah, it would work fine, the sub would just be underpowered. also, make sure that you have your gain set right, preferably with an o-scope. even though you're only running 1/3 of the sub's rms, if its clipped/dirty power, you can still blow your woofer. This /thread On 5/8/2011 at 7:38 PM, Kranny said: On 5/8/2011 at 7:35 PM, 'Maxim' said: It hurts me inside when I read stuff like this and remember you're 15 LMFAO so true Mitsubishi 3000GT (Old Build) Headunit: Pioneer 80PRS Frontstage: (2) McLaren Audio MLT-2 Tweeters & (4) PRV Audio MR Series Neo 6.5" Mids Substage: 4 15" Hybrid Subs - Tantric Motors & Sundown Softies Amps: Banda 2.4D Amp (Tweets), American Bass VFL 350.4 (Mids), and (2) Ampere 3800s Electrical :Singer 260A Alt & JY Power Lithium 2005 Chevy Colorado Ext Cab Headunit: Pioneer 80PRS Frontstage: 4 PRV 700Ti Tweets & 6 10" Delta Mids on 3000wrms Substage: 6 Fi BTL 18s in a 4th Order Walkthrough on 3 Wolfram 4500s Electrical: Singer "390" and JY Power My Official Feedback Thread
98crewcab Posted December 27, 2010 Report Posted December 27, 2010 yeah, it would work fine, the sub would just be underpowered. also, make sure that you have your gain set right, preferably with an o-scope. even though you're only running 1/3 of the sub's rms, if its clipped/dirty power, you can still blow your woofer. This /thread that......sorry. had to 06 2500hd, 6.0L, 4l80e, 4wd, (muah work truck) 7" BDS HC lift kit (5) 37x13.5R18 Toyo Open Country M/Ts (5) 18x10 Moto Metal MO962 tablet in lieu of deck blue tooth interconnect to soundstream eq (for volume control and bass control) 4 Alpine type r 10's 6 cubes net, 80sqin's port, tuned to 33hz 2 brutus brx5000.5's 2 pairs 3" polk audio for a pillars 4 pairs polk audio 6.5 comps 1 pair 8" polk audio for mids 2 xspower d3400 batteries.....learning alot from meade and his circle of some of the baddest installers ive seen- thanks guys, for not being so cocky and posting the way it should be done!P.S. Thanks Steve....for the demo!!!! loud as fauk!
nickportonova Posted December 27, 2010 Author Report Posted December 27, 2010 yeah, it would work fine, the sub would just be underpowered. also, make sure that you have your gain set right, preferably with an o-scope. even though you're only running 1/3 of the sub's rms, if its clipped/dirty power, you can still blow your woofer. Thanks, and yep I will be using my trusty o-scope to set my gain.
