Damn why didnt i think of that Brian
Team MaxRetribution
Si Vis Pacem Parabellum
Dip the whole thing down in hot lard then let it cool off. it'll be slick as astroglide then.
Anything that is as slick as astroglide has to be good! If nothing else if the gun fails just toss it towards your attacker and create a dangerous tripping hazard :rofl:
2000 GMC Sonoma
AQ20 FTMFW!
4 DC XL 15's
Cadence ZRS-C9
Infiniti Kappa 3.5's and 6x8's
Bravox 6.5 components
Im hoping the lighter trigger and ported barrel will help drastically :)
Team MaxRetribution
Posted (edited)
Listen to what Hugh G. Rection suggests. He builds exact copies of 1911's in his backyard.(I've seen it) :good:
Edited by Jbabycsx
2000 GMC Sonoma
AQ20 FTMFW!
4 DC XL 15's
Cadence ZRS-C9
i definitely am thats why im glad he chimed in on this because i want to build my daily carry piece into a fine performing machine and i searched and heard NOTHING but GREAT things about these Storm Lake Replacement Ported barrels
Team MaxRetribution
friend of mine has a strom lake semi drop-in barrel in his 5" 45 caliber 1911. benchrest one hole at 75feet. good barrels. ungodly accurate for ANYTHING, much less a semi-drop in.
Owner of BigAss Ports
then all you gotta do is figure out how in the hell your gonna hold on to it. lol
Correct me if im wrong but the porting is for heat dispersion right ??? Or does it level out the recoil some as well???
I can handle it but i will say its a punchy fucker with the recoil she likes to jump quite a bit
Team MaxRetribution
Hey hugh if i run that Ghostinc setup plus do the trigger job would that put me below 3.5lb pull ??
Team MaxRetribution
