does it matter or not
do you gain anything from running all 4 wires
or is hooking up just the 2 work just as well (3 if you count between the 2 subs)
sorry if this is general knowledge its my first time wiring anything
thanks for any help you can give
if the subwoofers are single voice coil 4 ohm, then you cannot really do any good with that 2 channel. wiring each subwoofer to each channel, and if you play music that does not have a perfect 50/50 left to right channel bass ratio, then the woofers will cancel each other out if they are put in a single chamber box. you can only bridge that amplifier if you can produce a final ohm load of 4 ohms or higher.
you'll get the same power either way.
Principal
JTech Consulting - Leader in 12-Volt Training and Product PlanningIt's not about how much power you have, but how well you use it
KFC-W112S 12" 8-ohm subwoofers
# injection-molded polypropylene woofer cone with high-roll urethane surround
# black stamped-steel basket
# power range (per sub): 50-200 watts RMS (800 watts peak power)
# frequency response: 28-800 Hz
# sensitivity: 90 dB
# top-mount depth: 5-9/16"
# sealed box volume: 1.25 cu. ft.
# ported box volume: 1.5 cu. ft.
# warranty: 1 year
does that mean there 8 ohm?
  • Who's Online   0 Members, 0 Anonymous, 443 Guests (See full list)
