Big_Mike Posted January 2, 2011 Report Posted January 2, 2011 Well I tried making a box and every way the port was about 8-10" short of port area. This is one of the boxes I made.. These are the dimensions. I tried to keep the height and width and depth the same on the outside of the box. This is going to be for a BTL 15 N2 running around 2000-2200wrms daily. Help anyone? Thanks :) Quote
Sanitarium Posted January 2, 2011 Report Posted January 2, 2011 those dimensions look spot on to me. Quote
Big_Mike Posted January 3, 2011 Author Report Posted January 3, 2011 Well I thought the port area had to be 12"-16" per cube. Quote
Torres Posted January 3, 2011 Report Posted January 3, 2011 Well I thought the port area had to be 12"-16" per cube. does not *have* to be. that is a general rule of thumb people go by. some people say it's no good, but imo otherwise you'll see people have boxes with like 5 sq inches of port per foot. so if you know what you're doing, you can go with more or less, otherwise i'd recommend staying within that area. either way you have almost 15 sq inches of port per foot which is fine imo Quote
Skrilla Posted January 3, 2011 Report Posted January 3, 2011 Not quite. He has close to 10.5in of port area per cubic foot. If you keep that just make sure you round the edges of the port to help get rid of any port noise you might have... Quote 2 HDC3 18's AQ2200D
Skrilla Posted January 3, 2011 Report Posted January 3, 2011 Whoops^ My mistake. I was looking at gross volume Yes, with almost 15in of port area per foot you will be perfect... Quote 2 HDC3 18's AQ2200D
Big_Mike Posted January 3, 2011 Author Report Posted January 3, 2011 Net volume is the whole box itself of just the port? Quote
Skrilla Posted January 3, 2011 Report Posted January 3, 2011 That's your actual cubic foot of the box after all displacement (port and sub). Since your box is 5.59ft you take away the port displacement (1.51ft) and your sub displacement (.14ft) and you're left with your net volume (3.94) Quote 2 HDC3 18's AQ2200D
Big_Mike Posted January 3, 2011 Author Report Posted January 3, 2011 So the total cubic feet of the box is almost 4 cubes? Quote
