stunninsabatino Posted January 3, 2011 Report Posted January 3, 2011 well here's the q, I have a 98' mustang, have a 1200w amp, 2 kicker comp subs (8ohm parallel wired down to 2ohms) with a sealed box. I would like to run a better amp, maybe 2, also want to install the Big 3 upgrade. I don't know what kind of amps i should run, i'd like to run Kicker amps, but don't know if i should run 2 300.1 amps or if i should get 1 big amp. Hopeully you all could give me some good feedback, and ill post some pics up so you kinda know what im workin with
tiller1 Posted January 3, 2011 Report Posted January 3, 2011 well here's the q, I have a 98' mustang, have a 1200w amp, 2 kicker comp subs (8ohm parallel wired down to 2ohms) with a sealed box. I would like to run a better amp, maybe 2, also want to install the Big 3 upgrade. I don't know what kind of amps i should run, i'd like to run Kicker amps, but don't know if i should run 2 300.1 amps or if i should get 1 big amp. Hopeully you all could give me some good feedback, and ill post some pics up so you kinda know what im workin with your subs are only rated 150watts???? you cant add more power? unless you upgrade subs! "yes... it will play like that all day!"
hdorre Posted January 3, 2011 Report Posted January 3, 2011 I'd just get one amp. It's easier on the electrical and makes cancellation impossible. It allows for an easier setup (don't need to gain match and set another HPF/LPF) On 5/8/2011 at 7:38 PM, Kranny said: On 5/8/2011 at 7:35 PM, 'Maxim' said: It hurts me inside when I read stuff like this and remember you're 15 LMFAO so true Mitsubishi 3000GT (Old Build) Headunit: Pioneer 80PRS Frontstage: (2) McLaren Audio MLT-2 Tweeters & (4) PRV Audio MR Series Neo 6.5" Mids Substage: 4 15" Hybrid Subs - Tantric Motors & Sundown Softies Amps: Banda 2.4D Amp (Tweets), American Bass VFL 350.4 (Mids), and (2) Ampere 3800s Electrical :Singer 260A Alt & JY Power Lithium 2005 Chevy Colorado Ext Cab Headunit: Pioneer 80PRS Frontstage: 4 PRV 700Ti Tweets & 6 10" Delta Mids on 3000wrms Substage: 6 Fi BTL 18s in a 4th Order Walkthrough on 3 Wolfram 4500s Electrical: Singer "390" and JY Power My Official Feedback Thread
raolito1980 Posted January 3, 2011 Report Posted January 3, 2011 WHy do you want a bigger amp? Do you plan on adding more subs to your setup? 2012 GMC SIerra CC System Build Headunit--Stock Sub Amp--DC 2.0k Subs--2-SA8v2's Enclosure--Need one made!! Highs Amp--Sundown SAX-100.4 Front Highs--Rockford Fosgate T2652-S Rear--Sundown Neo Pro 6.5 XS Power D2400--XS D3400 No Big Three yet! http://www.youtube.c...ser/raolito1980
stunninsabatino Posted January 3, 2011 Author Report Posted January 3, 2011 WHy do you want a bigger amp? Do you plan on adding more subs to your setup? No, i'd love to get more subs, but the only problem is the room lol. i'd like to get a better quality amp, its a sony amp, and it pushes em great but i think i'd be better off with a newer updated amp
