$9.95 kicker amp
99s10walled
...how do you tune the gains? ROFL. i know it has high level inputs but still...
In a OEM system the head-units output is matched to the amps input sensitivity. and since this is an OEM unit its non adjustable
you can cook bacon shirtless if you're not a pussy...lol
not hatin, but am i wrong here it looks as if the amp is not grounded its hooked directly to the battery. it that the way it should be.
DC.jpgDC POWER
there might be a little dial on the board itself :D. you can only hope
its a LOW PASS FILTER.
hmm some mids you shouldn't play at 150hz depending on size so this could work out.. or is this for below 150hz? im not reading just asking :pardon:
low pass means 1-150hz (in this case) is playing. anything over 150hz is slowly cut off.
thanks so much for posting that i beleave thats the amp they used in the srt4 neons with the 10" kicker sub ima order 4 when my girl gets here with a visa gift card around 8 i really hope theyll still be availible then
I picked up an MTX Sw1212 powered subwoofer today. This thing sounds amazing. 130 watts, 12" woofer with a passive 12" woofer tuned to 27 hz. Moving the pictures on the walls and my girl got wet from the bass when i showed her haha. Tonight should be good haha.
easy man they can cut off in the other direction!
yes in this case which is why i asked.. thank you
Johns.jpgSuburban Coming Soon
just friendly heads up, bout this amp, if you gonna use it on a factory system it may work fine, but if not. this amp has no controls you cannot match it up to a after market head unit, most after market head units put out more power than OEM, not only will you be boosting a dirty signal, but it will over drive the amp on the input and put out a distorted signal. it will make all the frequencies sound like one tone. you can put a line level and connect it reversed to accept RCA's but then your 100 watts rms will be more along the lines of 40 watts rms if that. i think 150 Hz is a bit high. you cannot adjust the x-over unless you use a coil. witch that will also lower the output power a bit. just throwing this out there. B)
  • Who's Online   0 Members, 1 Anonymous, 1822 Guests (See full list)
