I'm just like being stupid right now.. I can't think which way this goes:
My subs call for 1.5 cubes per sub. (So I need 3 cubes for this box). Each sub has a .15 displacement.
-I've got my box drawn up at 14x27x16 (HxWxD)
-and my port at 8x2x12 (HxWxD)
This gives my box a gross volume of 2.67, tuned to 33.91.
Did I do that right? I can't think if I need my box to be at 3.30, or 2.70.. (Because of the .30 sub displacement..)
:ehh:
I'm pretty sure it would be 3.30 before displacement, because once you put the subs in, they will displace .30, leaving you with 3 cubes.
Someone correct me if I'm wrong.
First System
2002 Impala LS 3.8L V6, 128,365k miles.
Alternator: DC Power 190Amp H/O Alternator
Headunit: Kenwood KDC-BT945U.
Speakers: MBQuart 6.5" Comps, 6x9 3-way.
Amplifer: Eclipse 3322 on front 6.5 components, and a Infinity Kappa One @ 2ohm- 800w
Subwoofers: 2 REAudio SRX12D2 wired to 2 ohm.
Box: 3.1cuft box tuned to 33hz. sealed off to cabin
Big 3- done with all Knukonceptz KCA 0 gauge.
Don't drop below 14.1v at full tilt. :)
3.3, and it's not gross volume buddy, go by net vol.
c'mon now, if i was shooting an 8 year old, it wouldnt be MY 8 year old.
i recently got a Pyle PL1590BL and i was building an enclosure for it tuned to 25 hz. i didn't have any tools to cut a circle so i hit it with a big hammer.
2003 Infiniti G35 Sport Sedan
Build in Progress
Posted (edited)
I'm also thinking that.. so my new designs would be:
14x32x16.5 port: 10x2x12
Giving me 3.31 cubes, tuned to 33.55.
Also, is having the port in the middle of the two subs a good idea? With the port facing towards me.. (It's going in my trunk with the back seats down.) Not sure which way to face subs with a ported box.. This will basically be 'walled' because my dimensions are squeezing this right in the opening where the seats fold down.
EDIT: Yea.. NET VOLUME, I'm glad this is going to be my first box that I can screw completely up on.. But I've got to learn this some way or another.. Got left over mdf, and two 12's on the way.
SO: 15x32x16.5 port: 11x2x12
Gives me a net of 3.29 cubes, tuned to 33.69.
HOW does that sound?
Edited by TLEJ
not sure yet, i'll play around with torres' calc if you give me your max dimensions so you dont have to screw up your first box and it will sound decent though..
or if you want to do it yourself, make sure you have like 14" of port per cube, and for 2 12's(guessing they're 12's) do like 60 sq in of port or somewhere around there..and i personally like just 1 port at a side of the box, so you use less wood, and the common port walls drop the tuning a little bit, which i like.
Build in Progress
Well I'll just give you this: my max is 18x33x28 (HxWxD).. I kinda wanted it tuned around to 33-34.. I want this to be loud and rattly.
It is 2 12"s,
Suggested Ported each: 1.5³ ft
Displacement each: 0.15³ ft
you want it to be rattly?? never heard that before, they make dampening to stop that.
Build in Progress
Posted (edited)
I knew right when I put rattly, the wrong idea was going to come out.. I just want it loud. Scratch me saying raddly. (It was jokish)
EDIT: Thanks Decaf, didn't notice that, hah.
Edited by TLEJ
