Should I Fuse the wire coming from my Alternator to Battery.
Is it necessary to fuse in between battery's if they them self's will be right next to each other, wires just long enough to parallel them together...
Is it necessary to Fuse the wire more then once going to the Amp if it is no longer then 2'?
if you have questions about my build to verify the answers for above click the link in my sig or I will just answer it.
Thanks Fellas, Austin
My First Build on SMD (Blow Through)
2004 Ford F-350 SD Lariat
Pioneer 3200BT DVD Deck
Infinity Reference Components not powered
Bully Dog Gauge Cluster Pyro, Turbo, Trans
SF3 SCT Tuner W/Customs
If you can't Join em' Crush em'
yes.
2006 Nissan Z Track.
My Feedback Thread
I know I did. I didn't even ask if I should I just told myself if its questionable then I'm doing it.
"WHOEVER SAID MONEY CAN'T BUY HAPPINESS MUST OF BEEN BROKE"
damn the one that is gunna piss my off is the 3 Battery bank in back all close to each other, I'm doing 2 runs of pos and neg, so I should fuse the 1' Long wires then huh?
so before I buy another 13 ANL fuse holders and spend 260$ quick can I get a second on the answers above! HeHe gotta do what you gotta do, I understand that. just not a fan of wasting :)
Edited by 55437Audio
I would put a fuse 18" before the batt bank and call it good. I don't think I've seen fuses in battery banks. Correct me if I'm wrong but that's how I would go about it.
for the runs that are like a ft long for my battery bank I didn't fuse those. anything over like 3ft , excluding runs from battery to amp I always fuse.
My Feedback Thread
I wish I didn't have to fuse between batt and amp! Damn orion and having no fuse in amps :/
you dont need to fuse in the rear batts, i didnt fuse mine it isnt like somthing is going to ground them out if they are not moving around or getting wet any of that crap save the money
  • Who's Online   0 Members, 0 Anonymous, 443 Guests (See full list)
