Processors FS, Old school and New MTX & Hifonics
1. Product:
Hifonics MLX-100 (Maxx-Link)
Universal Amplifier Control w/ Bass Knob
Old School Hifonics Plato III
10 band Vario-Frequency, Quasi-Parametric EQ
MTX LSX-1
2-way, Large signal Crossover
MTX LSB-1
Black Box, SPL Line driver, remote time dely
2. Specs:
Hifonics MLX-100
Features:
MaxxSonics Universal Amplifier Bridging Interface with a Synchronization Module
Permits interconnecting and linking mobile amplifiers into a master and slave configuration
Link up to five amplifiers max
Remote level control with LED clipping indicator
Master and slave control switch
Built-in setup tone
24dB Adjustable low-pass filter (35-250 Hz)
24dB Adjustable subsonic filter (15-35 Hz)
10dB Adjustable parametric bass EQ
Variable wide and narrow bandwidth control
0-180 degree Adjustable phase control
2 Channel RCA audio pass-thru
Dimensions: 6"L x 8-7/8"W x 1-1/2"H
Hifonics Plato III
10 bands of equalization
Variable frequency adjust
Stereo
input and output level adjust from -18 to +18dB
MTX LSX-1
LSX1 Features
2-way
Continuously variable low and high pass outputs between 30-400Hz high, 20-200Hz low
Up to 8 volt RMS input signal for integration with high voltage output source units
18dB/octave slope for greater protection of mid-ranges and tweeters
Continuously adjustable crossover points
Wire harnesses for speaker level input allow easier integration with OEM systems
1 Meg Ohm Isolation maintained between the Signal Ground and Power Supply Ground (eliminates ground loop noise)
External Bass Control (EBC) port connects to optional, dash-mountable EBC unit
MTX LSB-1
Our one-of-a-kind MTX LSB1, (a.k.a. “the Black Box”) is a dual function,
multi-purpose signal and remote turn-on processor. One of its primary
functions is to allow you to easily switch between two different subwoofer amplifier signal paths, for either sound quality listening or SPL listening. (“LS” refers to Large Signal, or the ability of the device to accept
up to a 10 volt RMS input signal).
Note: Unlike the infamous Black Box that tells what happens in a
plane crash, the only thing the LBS1 will tell about you is that
you have superior taste in audio equipment.
Sound Quality Listening
The low noise (Signal-to-Noise ratio better than 105 dB) attenuator is
typically used for the sound quality testing portion of an IASCA competition, or for listening preferences that emphasize sonic reproduction.
SPL Listening
The SPL setting routes the signal through a high pass filter. This allows
you to boost a narrow band of frequencies (typically at the “in-car resonance” of the system, or the port tuning frequency of a vented system)
to play obscenely loud without damaging your woofers.
Turn-on/Turn-off Delay
This feature allows you to delay turn-on of amplifiers and turn-off of
signal processors to prevent transient noise. Or, it can delay turn-on/turnoff of a system’s moving parts. The LSB-1 also features our patented Split
Shield™ bottom plate design and the MTX ISO-FEET™ non-conductive
mounting feet to prevent chassis-to-chassis ground loops
3. Description/Condition:
Hifonics MaxxLink
and
MTX LSX-1 are
Brand New in box, never used. Comes with all manuals and accessories they originally included
MTX LSB-1
is Used in my SPL car from 2002-2003. Has not been used since. No manual, but it works 100%. A few minor scratches
Hifonics Plato III
Bought it used in 2003 but never used it myself.
A few scratches but was test to function 100%.
No power Plug but can be made easily.
4. Price: :
$70 for each unit, shipping included to lower 48 states.
or
$220 for all 4 shipped at once in lower 48 states
5. Pictures:
Ed Lester
ShowtimeSPL Host
Showtime Electronics Video Marketing
My old Build Log
http://www.stevemead...08/#entry511451
http://www.youtube.com/showtimespl
5 time dB Drag Finalist
Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music
New Ride, 2008 HHR SS. Build under way.
Loudest score ever = 171dB
2009 dB Drag Racing, North American Points Champion
A price may help
There is, and has been prices since the OP opened the thread.
$70 each
Or
$220 for all 4
TEAM FLEX ISSUES
Car: 1985 Oldsmobile Delta 88 Royal
24" Rims
HU: 7" Carputer, Planet Audio EQ, iPhone.
Coax: T3 Audio 4" speakers
Subs: 2x 18" T3 Audio TSNS (walled)
Sub Amp: DC 9k
SOON TO COME
T3 Audio 6x9s
MB Quarts 6.5" comp set
MAYBE ADDED
2nd DC 9k
A price may help
Reading > You, lol
MTX LSB-1 has been sold
Ed Lester
ShowtimeSPL Host
My old Build Log
