Measure RCA output voltage?
I need to measure the output voltage of an equalizer/preamp i have, Can i just use a DMM and test between the positive and negative parts of the RCA cable coming out of it?
2009 Cobalt LT
Pioneer Headunit
2x Pioneer 6 1/2 (stock amp)
2x Pioneer 1" tweeters (stock amp)
2x Pioneer 6x9 (stock amp
4x Pioneer 6 1/2
Pioneer GM-6400F
Soundstream DTR 1700 R.I.P
2x Champion series PRO 12" subs
0 AWG Big 3, Stinger SP1700 battery
To come:
New or repaired DTR!!
I have an audiocontrol line driver.. good question because I've always done this by guesstimating
Currently:
* Hybrid Audio Legathia 3-Way Active Front Stage
* (2) Morel Ultimo 12's
* (2) Arc Audio 1100.1 XDi v2 (Strapped @1ohm)
* (1) Arc Audio 1200.6
* RF 360.3 DSP
Get a test tone cd, get a bunch of tones from 60 to 200 hz because each meter turns on in a different frequency range.
It would be a good idea to o scope your head unit first to see where it clips. if not I guess the 3/4 rule would go into effect.
Turn the track on and connect one lead to the tip prong, and the other to the outer metal edge of the rca (you're checking one at a time).
turn up the volume to where you should be gradually and see where it peaks. Multiply this number by .707.
That is to the best of my knowledge on how to do it.
oh yea, set your meter to AC, not DC.
Eclipse cd7000
  • Who's Online   1 Member, 0 Anonymous, 474 Guests (See full list)
