Mechman Alternators
i need the biggest alternator i can 'fit' , use on my truck , its a 05 f150 5.4L.
i know my truck its pcm... can i still use one of your alts ??//...
thanks. :popcorn:
No problem-
We have three different models:
250 "S"
250 amps by 1800 rpm
150 amps at idle
* Excellent output even as low as 500 RPM
16 Diodes, HD rectifier, totally bomb-proof for daily abuse
SALE = $349 (Reg. $449)
320 amp Rev Series
320 amps by 1800 RPM
8O amps by 800 rpm
65 amp diodes with custom solid copper rectifier
Totally durable for daily use
= $449
425 amp Goliath Series
425 amps by 1800 rpm
180 amps by 800 rpm
Includes in-dash adjustable voltage control
(16) Diode oversize rectifier with improved cooling
totally durable for daily use (full output should be limited to short periods)
= $699
and we also have dual and tipple alternator bracket kits available if you really want to get crazy...
Edited by MECHMAN
ill get the golliat in 2 weeks.
are these in stock ?
can i run 14v batteries with this alt (golliat) ?
how will i wire it ?...
Edited by heckvr4
We currently have all of the components in stock, we just have to assemble the unit.
You can run 14 volt batteries, but you have to not use the OEM alternator plug. Your truck has a PCM controlled regulator from the factory, so the alternator light will come on in your dash, but it won't hurt anything.
We include everything prewired, so all you have to do is hook up a single keyed hot remote wire.
  • Who's Online   0 Members, 0 Anonymous, 1629 Guests (See full list)
