With glassing, he means use fiberglass+resin, because resin itself doesn't adds a lot of strenght.
Resin is brittle.
I would recommend using fiberglass to reinforce the box+port.
Dowel rods are a good way to brace a port.
Resin is brittle.
i thought resin was too brittle; but I have never worked with it very much other than to make a few small panels.
dowel rods or all thread will probably be what I end up using. I already planned on putting 3-6 pieces of all thread thru the box, so I may just run one piece top to bottom and make sure it crosses paths with the port.
Clicky for build log....
2002 Tahoe
DC Power Inc 3 alt bracket with 2x230a. alts 1 stock
Eclipse CD5030
2 JL HD 600/4
4 Rockford Fosgate 2500bdcp's
4 DC Audio 18" XL's
4 Pr MB Quart Premium Components
200FT Stinger HPM 1/0
Rockford 360.2
No where near enough sound deadening
@moto211:: thanks; but I dont wanna give up that much airspace if I can help it.
2002 Tahoe
Eclipse CD5030
2 JL HD 600/4
4 DC Audio 18" XL's
Rockford 360.2
well you will be surprised of how little air space it takes up , 27 feet of 2x4 is one cubic ft, and if you use 3/4 x3" mdf is takes 67 feet, to equal 1 cubic ft, but bracing make the box , no bracing , no slamming , a smaller stronger box is better that a bigger box with no bracing !!!! good luck
CHECK OUT MY YOU TUBE PAGE
http://www.youtube.com/user/motoxxx211?feature=mhee
[/size]
  • Who's Online   0 Members, 0 Anonymous, 832 Guests (See full list)
