93' Ford Bronco SLOW Rebuild (slowest build EVER!)
or maybe its the fact there's no real updates just bunch pictures of writing haha
get some more pics of stuff we'll be interested in and you'll get some "love"
R.I.P!
(Nov-29-2009)
92 explorer
current build
ok ok :lol:
Working on my 93' Ford Bronco rebuild:
I have:
pioneer AVH-P6500
Infinity Reference 6032SI fronts
Infinity Reference 6832CF Rears
Crescendo CZ 6.5 kicks
Crescendo 1100.4
(2) DC Audio LvL 4 M2's
(1) Juicebox Blackcherry
Piece together amps & wiring
Bout to get:
Crescendo Amps
Crescendo Mids
Crescendo Tweets
Sky High Car Audio Wire
Rockford Fosgate 360.2 or .3
My Build
http://www.stevemeadedesigns.com/board/topic/97426-93-ford-bronco-rebuild-full-system-body-paint/
Nice start... Props to putting your system on paper...
but i got a question about the following picture...
Is the 0ga running through your door jam?
thanks... yea i got a lil old school in me with putting every thing on paper.
no the 0ga not running through the door jam. since I just put this system in to hold me over till after paint & body. The wire is throngh the some hole in the fire wall as the AM/FM antenna & it follows the antenna wire untill it pops out right there. but after paint im gone redo it & the 0ga will have its on hole & i might have 2 run of 0ga
I have:
pioneer AVH-P6500
Crescendo 1100.4
Bout to get:
Crescendo Amps
Crescendo Mids
Crescendo Tweets
My Build
Well this build is starting to go backwards...
Spent 2 weeks looking for the best paint & body shops around me here in michigan. Found some top rated ones & few little hood shop that do good work. But now things with truck want to go bad.
The problem: there is a short, busted relay, or loose wire some where in my truck & its draining my battery. plus from time to time in the last 3 weeks, when I cut the truck off there is this clicking noise coming from under the dash. sound like a relay is stuck open or closed. I can turn the key while this clicking noise is happening & it stops but then nothing happens its like the battery is dead. no lights, no dash lights, no motor, no door locks, & No Sound System but soon as the clicking stops it starts rite up or tries to start like its got a extra low battery power. then all i need is a jump to start it..
I have spent the last 2 day going over every wire, relay, connection, & ground/power in my truck i could get to. Found not wrong!! I even had the battery & atl checked at 4 different places. so now my truck is in the shop with ford techs going over thing wire by wire & even pulling the dash. so there goes some of the extra funds saved for paint n body & thats not counting my run into with the feds/sheriff before xmas...
The top rated shops link
I have:
pioneer AVH-P6500
Crescendo 1100.4
Bout to get:
Crescendo Amps
Crescendo Mids
Crescendo Tweets
My Build
No Call from the shop today... :(
still hoping its small & not have to rewire the whole truck with a fuse block wiring set from LMC or Jegs...
I have:
pioneer AVH-P6500
Crescendo 1100.4
Bout to get:
Crescendo Amps
Crescendo Mids
Crescendo Tweets
My Build
Got a call from the shop:
Damn there go $600 more... SMMFH
I was rite about this build starting to go backwards...
The shop say my atl bearings are bad, the belt bad, & the idler pulley is outta line...
This has just turned into one them extra long drawn out builds. My bad guys...
I have:
pioneer AVH-P6500
Crescendo 1100.4
Bout to get:
Crescendo Amps
Crescendo Mids
Crescendo Tweets
My Build
Going to pick up what's left of my truck today... No tell what else they found &/or if they could fix it.
:badmood2: :badmood2: :badmood2: :badmood2:
I have:
pioneer AVH-P6500
Crescendo 1100.4
Bout to get:
Crescendo Amps
Crescendo Mids
Crescendo Tweets
My Build
Down $600 & back to where I start.... (late posting this)
Just got my whip back yesterday before this big azz snow storm here in michigan. New stock alt (for now), battery, belt, & fixed the pulliy... was gone do a video when I get home but no day light & snow started. I did spend more on parts since i had to drive by the junk yard....
I got these parts:
to help me fix this front end:
I have:
pioneer AVH-P6500
Crescendo 1100.4
Bout to get:
Crescendo Amps
Crescendo Mids
Crescendo Tweets
My Build
That sucks about your troubles. My '84 Bronco II is siting waiting for a new engine. Can't wait to see your full size painted and such. :popcorn:
Click Links To View Build Logs
1994 - Mazda B3000 (Daily/Toy/Show)
2002 - Mazda Protege (Daily)
1995 - Hyundai Accent (R.I.P.)
1984 - Bronco II (Restoration Project)
Youtube Channel
  • Who's Online   1 Member, 0 Anonymous, 1838 Guests (See full list)
