DC Sound Lab
Hi
Just planning out my port for my two level 5 18s.
Just wondering what port area and tuning the level 5s like?
I want it to play flat from 20hz to 50hz... and shift masses of air (hair tricks ect).
Also thinking of running them in 15cuft.... is this too big? Also aiming for big numbers.
Power is 4 sundown 1500Ds @ 0.7ohm
Cheers fellas.
Id do 10 cubes after disp with 16 to 18sq" per cube tuned to 35hz
oh and what vehicle sir?
Edited by dc98hoe
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
Will they be strapped at .7? Please say no.
Getting dual .7 or 1 ohm subs would be a better choice.
Edited by hdorre
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
Getting dual 1.4 or 2 ohm subs would be a better choice.
i think they have to be 1.4s to get to .7
TEAM DC AUDIO
PREAMP:arcaudio
SUB AMP: 2-dc7.5s
BATTERIES:6-d1400s
Im sorry. I meant wiring each set of amps to 1.4 or 2 ohms. My bad. You should get dual .7s or dual 1 ohm coils.
If I were to use 2 amps on a single sub, Id either strap or use Rockford's MasterSync Technology.
If you already have the subs, have you thought of getting a single amp? That would allow you to wire to .7 ohms. Maybe a Soundigital 8k or 12k?
Edited by hdorre
LMFAO so true
:blush:
do 11 cubes after displacement, tune to 35hz, it will play down to about 24hz respectfully, and up to about 45ish, atleast mine did when i had the 3...
do about 15 sq inch of port per cube, and should turn out nicely
The DC Integra 3 18s to 6 15 build log
Team_DC-Derrick's Youtube
Team DC Audio
where theres a will theres a wall.......
I just realized Steve has reach Voldemort status, over on JP's site he is the one who will not be named....."We dont speak his name over here, fearing it will destroy us" LOL not even in hush tones
Cheers guys... here in the UK lots of people use around 8-10 sq" of port area per cube... I've have good results using such low port area with low tuning (27hz :-D). But after joining the smd forum I'm thinking of using 15-20sq" to see how results differ... I might use blockers to bring the tuning right down from say 38 to 25hz.
Would a bigger port be louder than a tighter one?
A smaller box increases power handling. A bigger box increases efficiency. So, a bigger box will be louder. Just make sure the sub will handle the combination of the amps and box size.
Edited by hdorre
LMFAO so true
:blush:
  • Who's Online   0 Members, 0 Anonymous, 4724 Guests (See full list)
