DodgerCannon Posted January 10, 2011 Report Posted January 10, 2011 Hi Just planning out my port for my two level 5 18s. Just wondering what port area and tuning the level 5s like? I want it to play flat from 20hz to 50hz... and shift masses of air (hair tricks ect). Also thinking of running them in 15cuft.... is this too big? Also aiming for big numbers. Power is 4 sundown 1500Ds @ 0.7ohm Cheers fellas. Quote
AA98hoe Posted January 10, 2011 Report Posted January 10, 2011 (edited) Id do 10 cubes after disp with 16 to 18sq" per cube tuned to 35hz oh and what vehicle sir? Edited January 10, 2011 by dc98hoe Quote TEAM DC AUDIO VEHICLE:98 chevy tahoe 2wd 3-4 drop HEADUNIT:alpine 9886 PREAMP:arcaudio FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door KICKPANELS:jl audio 5 1/4 REAR DOORS: dd components 6 1/2s HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV SUB AMP: 2-dc7.5s ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket WIRE:10-runs 0g front to back BATTERIES:6-d1400s TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
hdorre Posted January 10, 2011 Report Posted January 10, 2011 (edited) Will they be strapped at .7? Please say no. Getting dual .7 or 1 ohm subs would be a better choice. Edited January 10, 2011 by hdorre Quote On 5/8/2011 at 7:38 PM, Kranny said: On 5/8/2011 at 7:35 PM, 'Maxim' said: It hurts me inside when I read stuff like this and remember you're 15 LMFAO so true Mitsubishi 3000GT (Old Build) Headunit: Pioneer 80PRS Frontstage: (2) McLaren Audio MLT-2 Tweeters & (4) PRV Audio MR Series Neo 6.5" Mids Substage: 4 15" Hybrid Subs - Tantric Motors & Sundown Softies Amps: Banda 2.4D Amp (Tweets), American Bass VFL 350.4 (Mids), and (2) Ampere 3800s Electrical :Singer 260A Alt & JY Power Lithium 2005 Chevy Colorado Ext Cab Headunit: Pioneer 80PRS Frontstage: 4 PRV 700Ti Tweets & 6 10" Delta Mids on 3000wrms Substage: 6 Fi BTL 18s in a 4th Order Walkthrough on 3 Wolfram 4500s Electrical: Singer "390" and JY Power My Official Feedback Thread
AA98hoe Posted January 10, 2011 Report Posted January 10, 2011 Will they be strapped at .7? Please say no. Getting dual 1.4 or 2 ohm subs would be a better choice. i think they have to be 1.4s to get to .7 Quote TEAM DC AUDIO VEHICLE:98 chevy tahoe 2wd 3-4 drop HEADUNIT:alpine 9886 PREAMP:arcaudio FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door KICKPANELS:jl audio 5 1/4 REAR DOORS: dd components 6 1/2s HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV SUB AMP: 2-dc7.5s ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket WIRE:10-runs 0g front to back BATTERIES:6-d1400s TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
DodgerCannon Posted January 10, 2011 Author Report Posted January 10, 2011 0.7ohm per amp....1.4ohm strapped. The lvl 5s are dual 0.7ohm Quote
hdorre Posted January 10, 2011 Report Posted January 10, 2011 (edited) Will they be strapped at .7? Please say no. Getting dual 1.4 or 2 ohm subs would be a better choice. i think they have to be 1.4s to get to .7 Im sorry. I meant wiring each set of amps to 1.4 or 2 ohms. My bad. You should get dual .7s or dual 1 ohm coils. If I were to use 2 amps on a single sub, Id either strap or use Rockford's MasterSync Technology. If you already have the subs, have you thought of getting a single amp? That would allow you to wire to .7 ohms. Maybe a Soundigital 8k or 12k? Edited January 10, 2011 by hdorre Quote On 5/8/2011 at 7:38 PM, Kranny said: On 5/8/2011 at 7:35 PM, 'Maxim' said: It hurts me inside when I read stuff like this and remember you're 15 LMFAO so true Mitsubishi 3000GT (Old Build) Headunit: Pioneer 80PRS Frontstage: (2) McLaren Audio MLT-2 Tweeters & (4) PRV Audio MR Series Neo 6.5" Mids Substage: 4 15" Hybrid Subs - Tantric Motors & Sundown Softies Amps: Banda 2.4D Amp (Tweets), American Bass VFL 350.4 (Mids), and (2) Ampere 3800s Electrical :Singer 260A Alt & JY Power Lithium 2005 Chevy Colorado Ext Cab Headunit: Pioneer 80PRS Frontstage: 4 PRV 700Ti Tweets & 6 10" Delta Mids on 3000wrms Substage: 6 Fi BTL 18s in a 4th Order Walkthrough on 3 Wolfram 4500s Electrical: Singer "390" and JY Power My Official Feedback Thread
Team_DC-Derrick Posted January 10, 2011 Report Posted January 10, 2011 do 11 cubes after displacement, tune to 35hz, it will play down to about 24hz respectfully, and up to about 45ish, atleast mine did when i had the 3... do about 15 sq inch of port per cube, and should turn out nicely Quote The DC Integra 3 18s to 6 15 build log Team_DC-Derrick's Youtube Team DC Audio where theres a will theres a wall....... I just realized Steve has reach Voldemort status, over on JP's site he is the one who will not be named....."We dont speak his name over here, fearing it will destroy us" LOL not even in hush tones
DodgerCannon Posted January 10, 2011 Author Report Posted January 10, 2011 Cheers guys... here in the UK lots of people use around 8-10 sq" of port area per cube... I've have good results using such low port area with low tuning (27hz :-D). But after joining the smd forum I'm thinking of using 15-20sq" to see how results differ... I might use blockers to bring the tuning right down from say 38 to 25hz. Would a bigger port be louder than a tighter one? Quote
hdorre Posted January 10, 2011 Report Posted January 10, 2011 (edited) A smaller box increases power handling. A bigger box increases efficiency. So, a bigger box will be louder. Just make sure the sub will handle the combination of the amps and box size. Edited January 10, 2011 by hdorre Quote On 5/8/2011 at 7:38 PM, Kranny said: On 5/8/2011 at 7:35 PM, 'Maxim' said: It hurts me inside when I read stuff like this and remember you're 15 LMFAO so true Mitsubishi 3000GT (Old Build) Headunit: Pioneer 80PRS Frontstage: (2) McLaren Audio MLT-2 Tweeters & (4) PRV Audio MR Series Neo 6.5" Mids Substage: 4 15" Hybrid Subs - Tantric Motors & Sundown Softies Amps: Banda 2.4D Amp (Tweets), American Bass VFL 350.4 (Mids), and (2) Ampere 3800s Electrical :Singer 260A Alt & JY Power Lithium 2005 Chevy Colorado Ext Cab Headunit: Pioneer 80PRS Frontstage: 4 PRV 700Ti Tweets & 6 10" Delta Mids on 3000wrms Substage: 6 Fi BTL 18s in a 4th Order Walkthrough on 3 Wolfram 4500s Electrical: Singer "390" and JY Power My Official Feedback Thread
