mechman 270 amp alt problems
jeeps charge at 13.6, i end up around 13.9-14.1 on my back batt at idle, now, when i contacted matt he said all id need is the external reg., which is what you have, but another thing is that i hooked up my big 3 wrong at 1 point, it looked normal to me until i asked on here, idr what i did, but just double check the big 3 wiring, your fuses and such, if that doesnt work, contact matt @ mechman
do i gotta hook the ground up on the alternator to get it to work right?
That's how I have mine
2008 TahoeHU-PioneerMids/Highs amp- sundown 200.4Mids/Highs- hertz xls, hertz ml 700, audison voce tweetsAmp-2 AQ 3500sSubs-FI SP418sAlt-singer 350Big 3 1/0
Build Log
UBL My YouTube channel
i still got a stock alt so im just going on what i know, if there is a grounding stud on the alt itself, then yes you must ground the alt to whree you have you big3 ground, if any....
Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k!
Why would you EVER WANT flex?
huh?...flex is what can make the lows lower and more air being pushed correct?
me_zps0fb5a5b4.jpgMy FeedbackJeep-BuildlogPT LOSER buildlog
well whick way do i gotta turn the external regualtor to make it go up?
ok i need this thing running good tonight.. iv checked all the big 3 wires and put the ground from the alternator on it and its still not reading the right volts from it. i dont know what else to to so help me out
was the batteries full b4 u hoot the alt up? what happens to the voltage when u rev it up do it jump or say the same?
I know a lil about everything so dont call me Mr. Know it All.
  • Who's Online   1 Member, 0 Anonymous, 794 Guests (See full list)
