Like has been said you want equal runs of ground as power, the copper is far superior in conductance to the steel frame, if you ground to frame you want that as short as possible. You also what your amp grounds as short as possible, less resistance, equals less heat, HEAT is the ENEMY!!!! LOL And the more runs of cable you do the better distribution of current you will have, you have less resistance, because there is more metal, and it is better conductive metal(copper or silver tinned). Your alts will work less to produce proper voltage and respond faster to voltage drop, since you have more paths for the current to flow. :good:
TEAM SOUNDQUBED -- TEAM SOUTH
TEAM S.O.B. - Founder & Captain
3x Streetbeat World Record Holder
2017 MWSPL 1st place Mayhem & 4th Xtreme 4
2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4
2015 MWSPL 2nd place Mayhem & 4th Xtreme 4
2014 USACI 2nd place Streetbeat 5 - 162.6 db
2014 MWSPL 2nd place Xtreme 4 - 144.9 db
2013 USACI 1st place Streetbeat 4 - 161.9 db
2013 USACI 1st place Street Q+ - 162.8 db
2013 MWSPL 3rd Kaos2 & 4th Xtreme 4
2011 USACI 2nd place MOD 1001-2k - 160.0 db
2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db
2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest
Best score to date 164.4 db - Termlab Outlaw
MWSPL on Dash Legal door open (Music) - 162.5 db
Sealed on dash Legal (Music) - 161.1 db - Termlab
THE BLACK NASTY CURRENT BUILD & FAB
The Black Nasty (6) 15 Rebuild Log 2012
(4) 15 Walled Sierra Build Log
Evo X build log
Facebook page The Black Nasty
thats what i would do. but! if you cant afford neg runs you can use the frame as wire. :) same amount of negs as pos
does it matter how long the runs are if you ground to the frame?
in the front i went from back of alt straight down to frame 18" total 3 runs of 0g on each side of motor. then in back i went from my batterys through the floor to frame maybe 2ft. 6 runs also i have steady voltage for pulling 800+ amps
so your grounded with runs from the front to back and in the back your grounded to the frame?
he wouldnt be the first to say they did a 167 with a system like that (one that clearly DOESNT), but i have to say, he didnt beat me anywhere, ive never competed against the guy. If he thinks his does a 167, mine would probably put him in a coma. :hairtrick:
Makes more sense now. Thanks guys! I'm gonna run more ground straight off the back of the alts..
99 2dr Blazer
Kenwood KVT-614
SounDigital SD16k
4 Fi BTL 18s
4 hertz high energy 6.5s comps
4 stock ad244 alts
6 g31s batts
8 runs 0ga
  • Who's Online   0 Members, 0 Anonymous, 2212 Guests (See full list)
