how to wire my lanzar opti drive 2000d
ok im a noob to this site and a noob at wiring systems, learnin more everyday so your guy's help would be nice, ok from my understanding i have a mono block amp and the amp starts at 4 ohms and u divide that by however many speakers you put on the amp, so 2 speakers u would take the 4 ohms you started with and divide it by 2 and then your amp would then run on 2 ohms, im looking to run 3 pioneer premier pros to a lanzar opti drive 2000d so that would drop it down to 1.3 correct? but my speakers are dual voice coil so doesnt that make it almost like 2 speakers in one so would my amp then drop to .65 ohms? and if so would this amp be able to drop so low without blowing fuses? it has a built in fan if that matters at all
you will 99 percent sure pop the fuses, im not sure *too lazy to google* if the amp is one ohm stable, if it is just stay barely above one
Hahah damn cody
She ain't that sexy. I wouldn't even let her blow me. Those 10 pounds of make up would end up all over my crotch.
you dont find dubstep, dubstep finds you
hu: Pioneer MVH - P8300BT
mids: Alpine sps-600 all four corners
highs: Addictive Audio ECST25A,Memphis PR tweeters back
sub: 15 inch crossfire bmf
box: 4 cubes at 38 hz
amp: Rockford Fosgate Power 1000 25 To Life
140.7 on a non sealed trunk car with a five channel so far (old sub audiobahn aw1505q)
Build Log
http://www.stevemead...ima-56k-beware/
Feedback
http://www.stevemead...s-bfd-feedback/
The amp does not determine the ohm load. The woofers do.
You divide the power the amp has to offer at the ohm load you want across the 3 woofers.
For example if I had 2 rockford p2 15's at 250wrms a piece and I stick them at 2 ohms on a amp that does 500w at 2 ohms I will get 250wrms per-woofer.
From what I found this amp can only do 4 and 2 ohm but not for sure.
What coils are on the pioneers you have?
Edited by Rebel4055
Rest In Peace mother.
January 22, 1955 - February 14, 2013
http://www.stevemeadedesigns.com/board/user/35351-megrch/
The ohm load the amp will see is dependent on the impedance of the voice coils, how many voice coils on the subs, and how they're wired up. See this chart for clarification
http://mobile.jlaudio.com/support_pages.php?page_id=145
Alpine CDA-117...Memphis 16-X03
CDT Audio SQA-4100...SEAS Prestige H1396...Crescendo MP-6
Soundstream Rubicon 1.2500d...Digital Designs 3512f
its rated at .5 ohms (thats where it gets its 2000wrms from), and was everything i said about wiring and stuff right? if so would u just stick with the 1.3 ohms over the .65 even though "it says" to can go to .5? idk whether or not to believe em
I can not find any specs on that amp, I even went to their site and I still couldn't find it.
Where are you seeing its rated .5?
I need to know what coils your pioneers have.
Edited by Rebel4055
http://www.amazon.com/Lanzar-OPTI2000D-Optidrive-Competition-Amplifier/dp/B0002YU43C
i would say that if your electrical is up to par for the amplifier and the final VC configuration is going to end up being @ 0.65 ohm, yeah do that
200a alt. by Excessive Amperage
hc800 under hood & 2 Deka 9a31 in rear
1/0awg + big 3
SAZ 3000D
HDC3 18" @ 2 ohm
you've almost got it, in a way you're right about dividing it in half.
leave your amp completely out of it for now, just look at your subs. they have a set amount of resistance or impedance(ohms). lets say you have one dual 2 ohm sub, if you wire one positive terminal to the second, and the same for the negative terminals, you'll cut that dual two ohm impedance "in half" to 1 ohm, this is called parallel wiring. if you were to wire one of the positives to a negative, and then connect the positive and negatives that have no wires in them to you amp, you would have a 4 ohm impedance, this is called series.
here's a website you can play with various woofer quantities and voice coil configs.
http://www.the12volt.com/caraudio/woofer_configurations.asp?
if you want the most power out of that amp, while keeping it stable(if it's 1-ohm stable) then you'll want to wire your three separate subs in series, and then together in parallel. that will give you an impedance of 1.34(assuming you have dual 2 ohm subs)
(i was kinda late on this reply) :peepwall:
Edited by vengfuldev
Start out boxy, shape as you move along.
Dc Audio
Team Fur
this!
if you dont know what he means by electrical up to par meaning your car having *the big three* bigger power wire from alt to battery, engine ground to frame, and battery ground to frame
Hahah damn cody
Build Log
Feedback
  • Who's Online   1 Member, 0 Anonymous, 779 Guests (See full list)
