4 z V.3 18s 18v and a big 4th order
how bigs the bed, you know off hand? are you facing the port to the inside of the truck?
(2007 Chevy Tahoe LT)
Mechman 320A
OEM AGM
D'Amore Engineering HLC-2 Sig Converter
D'Amore Engineering E1500.1
Fi Audio Neo 3.5 12"
i have an 8' bed and its about 60in wide on the inside
this is what i have come up with so far if anyone knows anything about 4th orders please tell me if i did this right its my first time designing one
the magnet of the subs will be in the ported part so they will be firing into the sealed part
ported through the bed
Btw that was the first person. Ever banned by me while dropping a deuce. Feel privileged
as long as you got the ratios right (2:1 ?) and properly compensated for displacment of the woofers, you'll be fine. looks like a good basic bandpass design to me.
what do you mean ratios the volume of the sealed partition is the recommended size sealed from sundown and the ported partition is the recommended size as well is this wrong
if i understand this right the ported partition should be 2x's the size of the sealed? what size should the sealed partition be
I like it, My last bandpass played the same way and it sounds pretty good other then the Plexiglas moving, but this is all wood and firing right into the cab, I bet it's going to sound damn good
Mechman 320A
OEM AGM
ok so heres the deal i really need tires so i can either take my tax return and buy a set of 22s that i will eventually buy anyway or i could buy my air setup and just get some used tires that still have life in them ..... OR i could buy used tires and buy the rest of my subs wood and a cheap amp until i can save for some sundown 2500s
Air setup, but don't forget to get it lOoking pretty on the outside
thats probably going to come this summer when i can make the trip to my moms bf's shop to do work
What Sani meant with the 2:1 ratio is the front chamber volume ratio to the rear chamber volume. Make the rear chamber to Sundown specs (about 5-6 cubes) so the front would be 10-12 cubes.
Edit: Just went back and re-read, why do you want to mount them inverted?
so the rear chamber is the sealed?
i wanted to mound them inverted so i didnt have to calculate woofer displacement in the sealed partition because im unsure of what the displacement actually is also how did you get 5-6 cubes the site says they work in .2-.3 cu ft sealed each .2*8=1.6 .3*8=2.4 so thats how i came up with 2 cu ft for the sealed
