reverse light HID's how to
hey guys. . .
so one day, as i was reversing on my dark drive way i noticed that one of my reverse lights was out. usually even with both lights working it isnt that bright, so i figured that not only i needed new bulbs but i needed something brighter. so i figured i try some HID's to try to make them work with my reverse lights. i ordered some H11 6k's
some stuff i used:
-a Door Trim Removal Tool or Retainer Clip.
-some 10g wire about 15 to 19ft
-rubber adhesive
-1 15a fuse
-1 sheet of 8o grit sand paper
-1 automotive relay
-some zip ties
-hot glue gun with 1 glue stick
-self tapping screws and sta-kons
- black tape
my car is a 2007 mercury milan, now they dont make HID bulbs to fit in the reverse light housing of any car i believe.
i have worked with many different HID bulbs in the past so i felt that an H11 6k bulbs was suitable for my application. you can use any bulb but most you have to shave off the little tabs on the side.
i started by removing my battery and running some wire through an opening i found an the firewall and ran it to the trunk.
By mres3 at 2010-12-19
going inside under the dash and to the trunk.
REFF'S
My link
EBAY
back to the front, i started by crimping some of these on the wire i ran
i put the 15a fuse on the + wire that i ran going to the trunk
REFF'S
My link
EBAY
very cool concept, but at least finish the build log lol.
bro, i have everything uploaded and finished im also posting and remembering what i did. so keep checking back
REFF'S
My link
EBAY
fuckin a man can you resize all those damn pics?
let the pics load bro, they showing perfectly fine in my computer.
REFF'S
My link
EBAY
on to the back.
i took out the clips and removed the rear trunk lid.
ran the wire inside the factory loom to hide as much as i could.
trunk lid already removed and took out the reverse lights.
took out my hid ballast. some come like this the way i have it and some come with the blue plug on them. if so just fold down on the little metal tabs and take them out.
REFF'S
My link
EBAY
now i went a little bit ahead of my self and just wanted this done.
wiring the relay. find a good spot to hide it, i just used a little dimple i found on the trunk lid.
- the + wire i ran from the front to the trunk is getting connected to the 87 side of the relay.
- the + wire from the ballast is going on terminal 30, and the ground from ballast can be put on the anywhere you choose on the trunk lid, make sure you use a piece of sand paper and sand off the paint were you put your ground.
- 85 on the relay also needs to be grounded, i used the same ground for the ballast for terminal 85.
- now the + from your factory reverse light needs to go on terminal 86. take out your bulb and you should see a ground and positive. in this case my + wire was green, what i did was splice into it and connected it to 86.
here is what it should look like. i used a self tapping screw to hold it in place as well as my grounds.
my ground witch i sanded
find a good spot for the ballast, i just put mines behind the light.
REFF'S
My link
EBAY
damn those are some big pics!! they may be loading fine on your PC, but it's taking a day and a half to load larger than life pictures lol. hell i think my computer just gave up. there's only 3 fully loaded pics
really?
i dont know how to fix that, can any mod help with this?
REFF'S
My link
EBAY
  • Who's Online   1 Member, 0 Anonymous, 1573 Guests (See full list)
