SPL Gains!! Updates @page 30 (routing the port)
fecupe2001
So when you said you routed the po
Allright guys, first off, routing the port!!!!
As i always tell you guys, this starting score is always without playing with the seats , visors, mats, etc etc, it´s only meant for doing a before/after when i do an specific thing, anyways, here they come:
My port.
Can´t imagine what a way bigger flare could have gained me :)
So you just rounded the edges of the port?
Check out my Youtube channel www.youtube.com/user/ologiic
yes sir, the edges of the port!
my pleasure :)
Rounding the port makes it also longer, so maybe your tuning is a bit to high, so you gain with this "longer" (lower tuning) port also.
Don´t forget this rounding inside the box on the port :)
2008: Street B - 160 dbzzzzz
2009: Street B - 160,8 dbzzz
2010: Street B - 159,7 dbzzz
2011: Street B - 159,9 dbzzz
2012: Street B - 160,0 dbzzz
2013: Street Stock - 153,6 dbzzz
that´s why i tried to round the port with a very small pvc stripe, so i wouldnt change the tuning that much, but hell, looking at your signature then you are definitely a guy with way more knowledge than myself, if you say it was lower then it was lol
Every roundover I use gains me try noodle on top edge of box above port I gained
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
im walling the explorer now, dont think i´ll test anything else for this topic :(
Making gains with a wall?
not bad, i dont there are so many gains on a 4th order bandpass wall but we´ll see, will definitely test it a lot since right now it sucks ass!!!
Interesting as I'm planning to do a 4th order wall with 2 18's. I'll stayed tuned bro I know your not finished yet. Good luck with the build.
