ok so my front right tire is wearing on the inside alot and ive gone through 2 tires because of this so far. and i was wondering wat could be causing this.
and my back right tire has one massive bald spot on it like someone pulled the ebrake and just sat there burning out. wat could cause this
18" Sundown Zv4 D2
JL 1000/1 V1
XS Power D3200
depending on how wide the wear is on the front tire its either too much negative toe or too much negative camber either way go get your alignment checked out....
as far as the bald patch if you havent ripped the e-brake you may have a caliper that is sticking....
Team Devastation Mixed Martial ArtsMachado Brazilian JiujitsuOnce I lock it on there's no escape I don't train to make you tap, I train to tear your arm, leg, or head off. Its your job to tap before I can do that -Pain is only weakness leaving the body, its kill or be killed and only the strong survive...Rockford FosgateDigital DesignsFi Car AudioCrossfire Car Audio
^ what they said. allignment appears to be your problem but them again it could be your balljoints going bad get them both checked
2005 Ford Ranger Reg cab
Build in Progress
T3 Audio T2000 12
ARC SE4000
Stinger HPM 1/0 Wire
DC power 270xp
Batts: 1 Redtop up front and a Stinger SPP2250 in the back
Hopes to be in and around a 150....weel see
my youtube channel
http://www.youtube.com/user/steph3n1
Team DBs (Driven By sound)
  • Who's Online   0 Members, 0 Anonymous, 951 Guests (See full list)
