93v8blazer Posted January 19, 2011 Report Posted January 19, 2011 any one got any ideas on what amp or amps i should run? im running 2 re mt 12s custom box thats 4cft at 40hrtz both the subs are dual 1.7. i was thinkin 2 ap3000 and running each coil off a channel to make 3k at each sub. i have the electric 2 back it up and any suggestions would be apperciated. Vehicles 93 blazer 99 cavi big 3 2 re mt 12s custom box 4cft 40htz soild audio 1200 wired at .5 ohms projects 93 s10 blazer small bock needing finshed
Boon Posted January 19, 2011 Report Posted January 19, 2011 If the subs are dual 1.7's and you put a coil on each channel of 2 AP3000's you'll get ~1600wrms per sub. Which isn't really enough for them. Does AQ still make the 2200D? Get 2 of them, run 1 on each sub at 0.85 ohms. 10.x volts fo' life!
AMI CUSTOMS Posted January 20, 2011 Report Posted January 20, 2011 If the subs are dual 1.7's and you put a coil on each channel of 2 AP3000's you'll get ~1600wrms per sub. Which isn't really enough for them. Does AQ still make the 2200D? Get 2 of them, run 1 on each sub at 0.85 ohms. Yes AQ still makes the 2200D and yes do that get two and run 1 to each. TEAM SOUNDQUBED -- TEAM SOUTH TEAM S.O.B. - Founder & Captain 3x Streetbeat World Record Holder 2017 MWSPL 1st place Mayhem & 4th Xtreme 4 2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4 2015 MWSPL 2nd place Mayhem & 4th Xtreme 4 2014 USACI 2nd place Streetbeat 5 - 162.6 db 2014 MWSPL 2nd place Xtreme 4 - 144.9 db 2013 USACI 1st place Streetbeat 4 - 161.9 db 2013 USACI 1st place Street Q+ - 162.8 db 2013 MWSPL 3rd Kaos2 & 4th Xtreme 4 2011 USACI 2nd place MOD 1001-2k - 160.0 db 2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db 2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest Best score to date 164.4 db - Termlab Outlaw Streetbeat 4 - 161.9 db Streetbeat 5 - 162.6 db MWSPL on Dash Legal door open (Music) - 162.5 db Sealed on dash Legal (Music) - 161.1 db - Termlab THE BLACK NASTY CURRENT BUILD & FAB The Black Nasty (6) 15 Rebuild Log 2012 (4) 15 Walled Sierra Build Log Evo X build log Facebook page The Black Nasty
