XS Power
So I'm about to order a new battery for my yukon. This will be a replacement and the only battery I will be running. My system has about 1500rms. I was going to go with a D1200, but after some thinking, i may be going with a 3400. So I saw that they have a S and D 3400 and was wondering what the differance is between the two? The only thing that i can see is that the S model has a steel case and the D has a re-inforced plastic case. When researching the D1200, they recomended to go with what seemed to be a sheet metal case to keep the battery cool from engine heat. So if I order a S3400, i should be good then right.
2006 GMC Yukon
Pioneer HU
SHCA ran throughout
Crescendo BC3500
One 18 AA Mayhem in a 4th order
ZED Levithian 6 channel
Rainbow Dual 6.5 comps ran Active
http://www.stevemeadedesigns.com/board/topic/155628-matt14s-yukon-mayhem-in-a-4th-ordernew-amps-and-bats/page-3
They are the same now.
TEAM SOUNDQUBED -- TEAM SOUTH
TEAM S.O.B. - Founder & Captain
3x Streetbeat World Record Holder
2017 MWSPL 1st place Mayhem & 4th Xtreme 4
2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4
2015 MWSPL 2nd place Mayhem & 4th Xtreme 4
2014 USACI 2nd place Streetbeat 5 - 162.6 db
2014 MWSPL 2nd place Xtreme 4 - 144.9 db
2013 USACI 1st place Streetbeat 4 - 161.9 db
2013 USACI 1st place Street Q+ - 162.8 db
2013 MWSPL 3rd Kaos2 & 4th Xtreme 4
2011 USACI 2nd place MOD 1001-2k - 160.0 db
2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db
2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest
Best score to date 164.4 db - Termlab Outlaw
MWSPL on Dash Legal door open (Music) - 162.5 db
Sealed on dash Legal (Music) - 161.1 db - Termlab
THE BLACK NASTY CURRENT BUILD & FAB
The Black Nasty (6) 15 Rebuild Log 2012
(4) 15 Walled Sierra Build Log
Evo X build log
Facebook page The Black Nasty
So what about this sheet metal case that they recomend? Is it worth it? I can get from Jegs a s3400 shipped for about 250 and thats the cheapest i found shipped. They dont have the d3400
2006 GMC Yukon
Pioneer HU
SHCA ran throughout
Crescendo BC3500
My S3400 came with no case maybe built in it but don't really know. The other difference from S and D versions is that the S versions come with the battery posts and the D doesn't unless you order them.
you will be fine with just the battery and maybe the XS Power 589 to expand connections to the battery. I got mine from jegs also! Damn good battery.
As said above the S3400 and D3400 are the same exact battery. Only differences are the S3400 has red decals and comes with automotive posts. The D3400 has blue decals and comes with hardware to run ring terminals. If you would rather have the blue decals and run it under the hood with automotive terminals, then you can purchase a set of 580 SAE Automotive Posts.
If you are running side posts then you may want to look at the 551 or 555 iBar kits. If you have any other questions just let me know.
So i just got done installing the S3400. I did order the ibar kit. Had to run some new 1/0 for the alt and amp wire. See how it is tommorrow. A littl to late to crank it up tonight
2006 GMC Yukon
Pioneer HU
SHCA ran throughout
Crescendo BC3500
  • 13 years later...
