How To Properly Fuse Amps and Rear Batteries
Did it Help
34 members have voted
  1. 1. Did this Guide Help You?
    • Yes - Thanks :D
    • No - Still Confused :( (Post Why So I Can Help)
    • Didn't Need the Help (Already Know How)
    • I am stupid! Why am I here?
This is a picture I made to help all those who have trouble on adding a rear battery or fusing stuff.
As far as the alternator Fusing goes, I have seen some people not fuse this, and some fuse it. As far as I see it, if that fuse blows, its because that wire shorted or is about to burn up, and if that is going to happen your battery is going to discharge like a MOFO, which could cause it to explode or set fire. You are better off only destroying the battery by fully discharging it as you drive, after the fuse blew, then to have your battery set fire. If it were me, I would also fuse next to the alternator just in case it shorts the wire, that way your alternator isn't driven into a full on load way higher then it could take. Either way, I have seen people not fuse this wire at all, and some fuse it. If you do fuse it, do it to what your wiring can take, and fuse it the highest that the wiring can take. Don't be afraid to run more then one wire for any of these wires, as the more wiring the less resistance.
If you have any comments on making this better let me know!! Hope this helps all of those who need it!
Here are some videos on what batteries do if you short them, aka when you don't use a fuse and it shorts out, I didn't make these videos, just found them:
Shorting out a battery! Don't Do this at Home Kids!
http://www.youtube.com/watch?v=P11WbduMKhY&feature=channel_video_title
http://www.youtube.com/watch?v=ExS43bv462M&NR=1&feature=fvwp
Just Imagine if that were an XS Power Battery XD
2006 Mazda3 Hatchback Black 5 Spd Manual
Pioneer 4300DVD
2 Sundown SA-12 (34hz Tune, 3.22 cubes, 14.5 inches per cube, Triple Baffle)
Kicker 10ZX2500.1 (2845 RMS) Sub Amp
Kicker 11ZX650.4 (705 RMS) Mid Amp -- (3 Amps)
Kicker KQ3 Active Crossover
Kicker KQ30 Equalizer
Kicker 09QS60.2 Components (Woven Carbon Cones)
Kicker 09QS65.2 Components (Woven Carbon Cones) - (3 Sets)
2/0 Gauge Electron Beam Technologies (3 Runs, 2 +, 1 -)
1/0 Gauge KNU Kollasal Flex (1 Run for -)
300 Ft Kicker X-Series 16 Gauge Speaker Wire
XS Power D3400 (Rear)
XS Power D3100 (Front)
Singer Externally Regulated Alternator (Being Built)
+ The Love for Car Audio and BASS <3
UBL Build Log <------- Click Here-------> Normal Build Log (For Comments)
pretty cool.
Thanks!!
Most of the experienced people won't care about this, but for those who are new this will help a lot :P
Pioneer 4300DVD
i like, and understand alot better lol. Thanks !
Team Subsonic Lows
Get your garbage EMF products of my amp bitch
Man....it makes a nice work bench ;)
good to hear, thats all I wanted :P
Pioneer 4300DVD
The normal setup picture you have, the fuse next to the amp is not doing anything, the fuse up by the battery will protect the amp, the second one is a waste.
TEAM SOUNDQUBED -- TEAM SOUTH
TEAM S.O.B. - Founder & Captain
3x Streetbeat World Record Holder
2017 MWSPL 1st place Mayhem & 4th Xtreme 4
2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4
2015 MWSPL 2nd place Mayhem & 4th Xtreme 4
2014 USACI 2nd place Streetbeat 5 - 162.6 db
2014 MWSPL 2nd place Xtreme 4 - 144.9 db
2013 USACI 1st place Streetbeat 4 - 161.9 db
2013 USACI 1st place Street Q+ - 162.8 db
2013 MWSPL 3rd Kaos2 & 4th Xtreme 4
2011 USACI 2nd place MOD 1001-2k - 160.0 db
2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db
2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest
Best score to date 164.4 db - Termlab Outlaw
MWSPL on Dash Legal door open (Music) - 162.5 db
Sealed on dash Legal (Music) - 161.1 db - Termlab
THE BLACK NASTY CURRENT BUILD & FAB
The Black Nasty (6) 15 Rebuild Log 2012
(4) 15 Walled Sierra Build Log
Evo X build log
Facebook page The Black Nasty
Nice diagrams and info!
Thanks, btw you don't live that far from me, I used to live in perham, mn :P
Pioneer 4300DVD
I reality it is not doing much, but this is my reasoning behind it. Many amps have built in fusing, to protect the amp if there is too much current going to it. The fuse right outside the amp on the normal setup is if your amp comes with an external fuse. Although its not really that useful, it is designed to protect the amp incase of a short curcuit, whether it would help I have no clue. But lets say you run 0 gauge wire to a 1500 watt rms amp, that 0 gauge should be able to take 300 amps all day, so you fuse that wire up front at 300 amps. But the amp will never ever use that much current, and if it did it would ruin it, so you place a ~150 amp fuse next to the amp just in case the amp decides to be stupid. In reality its not really protecting much, its just fusing the amp externally instead of internally like many smaller amps.
Pioneer 4300DVD
  • Who's Online   0 Members, 0 Anonymous, 991 Guests (See full list)
