XS Power
two 3100s should cover you
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
if you have three now why dont you just supplement them. I dont know who makes them for treo but im sure they are just something else rebadged.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
im thinking they come from kinetik?? what do you mean supplement them? im thinking 2 3100s and a 1200 under hood
I have 2-3100s in the back and a 3400 and 2400 in the front.do a 3400 under the hood or 2 if you have a 2nd battery tray. then 2 3100s in the back. with a couple runs of 0g 2-pos 2-neg you should be set. oh i have 2 DDm4s and 3-220 alts with 9-runs of0g and my voltage stays in 14s on music
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
if you have three of those why not just get three more. I dont know the specs on them though so I dont know if the 6 would be cheaper and more power than the 3100s or what not following me.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
i was just thinking i could use less xs batts vs treos so i would save some weight
theres pros and cons for doing it either way. thats up to you decide. :drinks:
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
