7jezuz7 Posted January 21, 2011 Report Share Posted January 21, 2011 (edited) If it's an amp worth repairing then go that route. Locally would probably be a lot cheaper but there is db-r http://www.db-r.com/ But don't give up just yet, maybe they want you to buy an amp from them. You did take it to them working, how is it that all of a sudden it just broke? Edited January 21, 2011 by 7jezuz7 Quote An Audio Technix 18" Strato on a Kicker KX120.2 My Youtube Bass Vids Updates When Possible... I've bought from JBurt09, OrionStang, bcpballer64, LoudNLow931, audioman21, and CJ18 from here (as refs) Link to comment Share on other sites More sharing options...
Craig28 Posted January 21, 2011 Author Report Share Posted January 21, 2011 If it's an amp worth repairing then go that route. Locally would probably be a lot cheaper but there is db-r http://www.db-r.com/ But don't give up just yet, maybe they want you to buy an amp from them. You did take it to them working, how is it that all of a sudden it just broke? yeah theyre blaming it on me though. they said that it was arcing because of bad connections, which isnt my fault because i disconnected everything before i took it in. they want me to buy a 1200 watt kicker amp, which is definitely not enough for my xxx Quote TEAM DC Everything is a 150 on th earometer Well I guess punching a woman is a good way to test your strength! You never know how strong you are until you cold-cock a woman in the head and break that bitches jaw. Next time she tries to punch you in the stomach, whip your wiener out and chase her around. Show her who's boss. AlphaDamp CLD Mat - Get more sound deadening using less sound deadener Link to comment Share on other sites More sharing options...
Craig28 Posted January 21, 2011 Author Report Share Posted January 21, 2011 but it isnt anything power related that blew, its the fuckin inputs that dont work. Quote TEAM DC Everything is a 150 on th earometer Well I guess punching a woman is a good way to test your strength! You never know how strong you are until you cold-cock a woman in the head and break that bitches jaw. Next time she tries to punch you in the stomach, whip your wiener out and chase her around. Show her who's boss. AlphaDamp CLD Mat - Get more sound deadening using less sound deadener Link to comment Share on other sites More sharing options...
carlosg_313 Posted January 21, 2011 Report Share Posted January 21, 2011 If it's an amp worth repairing then go that route. Locally would probably be a lot cheaper but there is db-r http://www.db-r.com/ But don't give up just yet, maybe they want you to buy an amp from them. You did take it to them working, how is it that all of a sudden it just broke? yeah theyre blaming it on me though. they said that it was arcing because of bad connections, which isnt my fault because i disconnected everything before i took it in. they want me to buy a 1200 watt kicker amp, which is definitely not enough for my xxx so if everything turns on, and no bass, then check your power wire. if your remote wire is connected to it, it can turn on the amp, but wont play music without the power wire. make sure the RCAs are not connected to where it says "output", and like the person above said, double check your wiring from the sub to the amp, which if you wired a negative to a positive, nothing would be heard. Quote How do the Japanese feel about bass?You know that since 03/11/11 Progene? I just saw that stuff on CNN. They said it makes your junk shrink all up. lol.im pretty sure the op wont even notice if it gets even smaller. Refs - Pstone11, porksoda, coleman Link to comment Share on other sites More sharing options...
CaptainzPlanetz Posted January 21, 2011 Report Share Posted January 21, 2011 What amp is it, and also if you can get some gut pics, and see if anything looks burnt Quote ¿ǝɯɐƃ ǝɥʇ Trolls never learn............ All BS aside, If I see one more comment in here that is NOT about the pre-sale, I will start the vacations. And that includes the trolls feeding the trolls. YOU THE ONE THAT SOUND LIKE A OGER AND HUMPBACK/TROLLS? Add "SMDLIFER" on Xbox LIVE to play with other SMD members. Link to comment Share on other sites More sharing options...
Craig28 Posted January 21, 2011 Author Report Share Posted January 21, 2011 If it's an amp worth repairing then go that route. Locally would probably be a lot cheaper but there is db-r http://www.db-r.com/ But don't give up just yet, maybe they want you to buy an amp from them. You did take it to them working, how is it that all of a sudden it just broke? yeah theyre blaming it on me though. they said that it was arcing because of bad connections, which isnt my fault because i disconnected everything before i took it in. they want me to buy a 1200 watt kicker amp, which is definitely not enough for my xxx so if everything turns on, and no bass, then check your power wire. if your remote wire is connected to it, it can turn on the amp, but wont play music without the power wire. make sure the RCAs are not connected to where it says "output", and like the person above said, double check your wiring from the sub to the amp, which if you wired a negative to a positive, nothing would be heard. they called and said it didnt work with their test bench's subs either. Quote TEAM DC Everything is a 150 on th earometer Well I guess punching a woman is a good way to test your strength! You never know how strong you are until you cold-cock a woman in the head and break that bitches jaw. Next time she tries to punch you in the stomach, whip your wiener out and chase her around. Show her who's boss. AlphaDamp CLD Mat - Get more sound deadening using less sound deadener Link to comment Share on other sites More sharing options...
Craig28 Posted January 21, 2011 Author Report Share Posted January 21, 2011 im gonna go get it and take the sub out and check the wiring... Quote TEAM DC Everything is a 150 on th earometer Well I guess punching a woman is a good way to test your strength! You never know how strong you are until you cold-cock a woman in the head and break that bitches jaw. Next time she tries to punch you in the stomach, whip your wiener out and chase her around. Show her who's boss. AlphaDamp CLD Mat - Get more sound deadening using less sound deadener Link to comment Share on other sites More sharing options...
BassHead1990 Posted January 21, 2011 Report Share Posted January 21, 2011 haha I could have told you that they were going to tell you something was wrong lol they just want comission from you, I'd be like thx and take it home and connected it yourself Quote (2007 Chevy Tahoe LT) Mechman 320A OEM AGM D'Amore Engineering HLC-2 Sig Converter D'Amore Engineering E1500.1 Fi Audio Neo 3.5 12" Link to comment Share on other sites More sharing options...
Craig28 Posted January 21, 2011 Author Report Share Posted January 21, 2011 okay so now i have a question. he says he took my xxx and wired it to 4 ohms, and then bridged this kicker amp to 2 ohms so its getting about 1200 watts. all i can find about the amp is 850w MAX at 4 ohms bridged. it doesnt even say anything about 2 ohms. what the hell am i supposed to tell this guy Quote TEAM DC Everything is a 150 on th earometer Well I guess punching a woman is a good way to test your strength! You never know how strong you are until you cold-cock a woman in the head and break that bitches jaw. Next time she tries to punch you in the stomach, whip your wiener out and chase her around. Show her who's boss. AlphaDamp CLD Mat - Get more sound deadening using less sound deadener Link to comment Share on other sites More sharing options...
white4d96 Posted January 21, 2011 Report Share Posted January 21, 2011 Oh man. GET YOUR CAR BACK FROM THAT CROOKED-ASS SHOP ASAP!!! They are trying to fuck you eight ways to Sunday with no lube or even a goddamned reach-around. If you had the subs wired for a four-ohm load there is NO WAY they can wire it to 2 ohms. They're just taking you for a ride to try and get you to buy their shit. Quote Too many projects, too little time... Link to comment Share on other sites More sharing options...
