sean 371 Posted September 5, 2007 Report Posted September 5, 2007 Ripped out my wall today, so if anyone wants some cheap subs to play around with hit me up I'll send you a couple. Box is 7 cubes net, and about 8.77 cubes gross. No pics up yet, this is just to tease you guys and hopefully generate some interest. I just gotta cut the baffles and the box is done. Sub is a Fi 18" BTL (thanks to Steve), amp is a US Amps MD-3D (thanks to Ray) A couple links to some box builds: Tahoe Box 1, Tahoe Box 2, Nissan Titan, VW GTI, Mini-Bump, Hummer H2, Ford F-150 My own car builds (current setup --- under construction): Overall Thread, Kickpods, Dash, Back Doors Subwoofer Wall
Derrick824 Posted September 5, 2007 Report Posted September 5, 2007 Box is 7 cubes net, and about 8.77 cubes gross. What the port specs & tuning? Is it going to be sub up and port back? You can give us just a little more info to hold us over. Did you ever get your wall metered? I know it wasn't a lot of power but the cone area should have more then made up for it.
sean 371 Posted September 5, 2007 Author Report Posted September 5, 2007 My wall was ear-metered by both Steve and Ray...(not a TL, but close enough haha). They said because of all the cancellation i was getting by having the wall face forward without sealing it off from the back, it was only hitting like 138. (they both said the same number without knowing what the other said). Box is tuned to 32 hz with 81" of port. Sub up port back, sub is in the center, port on the left. Sub will be flushmounted, and a 1/4 inch mdf trim panel will go over the visible sides, and i have a couple ideas for that too. should look just as good as itll sound. pics are loading now. A couple links to some box builds: Tahoe Box 1, Tahoe Box 2, Nissan Titan, VW GTI, Mini-Bump, Hummer H2, Ford F-150 My own car builds (current setup --- under construction): Overall Thread, Kickpods, Dash, Back Doors Subwoofer Wall
sean 371 Posted September 5, 2007 Author Report Posted September 5, 2007 Pics: the remains of my old box after 10 minutes with a sledgehammer... the caulk i used to seal the port was stronger than I thought... how it sits now, im done for the night: A couple links to some box builds: Tahoe Box 1, Tahoe Box 2, Nissan Titan, VW GTI, Mini-Bump, Hummer H2, Ford F-150 My own car builds (current setup --- under construction): Overall Thread, Kickpods, Dash, Back Doors Subwoofer Wall
sean 371 Posted September 5, 2007 Author Report Posted September 5, 2007 still need to double baffle the bitch and install the new amp. then vids will come. even tho i only have stock alt, and the starter redtop. need much more electrical to feed 2800 watts... A couple links to some box builds: Tahoe Box 1, Tahoe Box 2, Nissan Titan, VW GTI, Mini-Bump, Hummer H2, Ford F-150 My own car builds (current setup --- under construction): Overall Thread, Kickpods, Dash, Back Doors Subwoofer Wall
jasonw30 Posted September 5, 2007 Report Posted September 5, 2007 looks good and x2 on the vids. 2002 nissan frontier crewcab eclipse cd2000 mb quart prem's fr&rear rf p4004
sean 371 Posted September 5, 2007 Author Report Posted September 5, 2007 thanks jason A couple links to some box builds: Tahoe Box 1, Tahoe Box 2, Nissan Titan, VW GTI, Mini-Bump, Hummer H2, Ford F-150 My own car builds (current setup --- under construction): Overall Thread, Kickpods, Dash, Back Doors Subwoofer Wall
jasonw30 Posted September 5, 2007 Report Posted September 5, 2007 what are you going to cover it with? 2002 nissan frontier crewcab eclipse cd2000 mb quart prem's fr&rear rf p4004
sean 371 Posted September 5, 2007 Author Report Posted September 5, 2007 you'll see... A couple links to some box builds: Tahoe Box 1, Tahoe Box 2, Nissan Titan, VW GTI, Mini-Bump, Hummer H2, Ford F-150 My own car builds (current setup --- under construction): Overall Thread, Kickpods, Dash, Back Doors Subwoofer Wall
