tax returns = new system????
taxes coming back next week heres what i got pickd out for my budget build (99 expo)
612's 3000watts
Hifonics HFI12D4 "12" 600 watt dual voice coil high output car subwoofer
* 12” 600 watt Dual Voice Coil 4 Ohms Subwoofer
* 600 watts Peak
* 300w RMS
* Impedance: Dual 4 ohms
* Injected Poly Light Rigid Cone
* 1” NBR Reinforced Rubber Surround
* Integrated One Piece Poly Cotton Spider
* Nickel Plated Push & Insert Speaker Terminals
* Dual 4 ohm High-Temperature KSV Voice Coils
* Poly Light Dust Cap
* Heat Dispersion Ported Back Plate
* Ultra Ridged Chrome Stamped Steel Basket
* High Strength ABS Motor Cover
* Large Air Cooled Magnet Assembly
* Sensitivity: 88 dB
* Dual Voice Coil 4 Ohm
* Rubber Surrounds
* Sealed Box Volume 1.25 - 2.15 cubic feet
* Ported Box Volume 1.75 - 2.5 cubic feet
* Sensitivity 88 dB
* Xmax: 11 mm
* Top Mount Depth 5.64"
2010 NEW LEGACY LA2770SL 1000WATT CAR AUDIO STEREO AMP
LA2770SL
# 2 Channel 1000 Watt Bridgeable Mosfet Amplifier (Silver)
# 2 x 500 Watts Max Output
# 1 x 1000 Watts Bridged
# Dual Fully Adjustable Electronic Crossover
# Soft Turn On/Off Circuit
# 2 Ohm Stereo Stable
# Dual MOSFET PWM Power Supplies
# Variable Gain Control
# Remote Turn On
# Heavy Duty Aluminum Alloy Heat Sink
# Hi/Lo Level Molex Input
# Power & Protection L.E.D�s
# S/N Ratio: >95dB
# Frequency Response: 15-30KHz
# THD: <0.04%
# Fully Protected Circuitry
# Dimensions: 11.1''W x 2.2''H x 7.5''L
# Fuse: 15A x 2
what ya think?
I think that amp is gonna put out like 300w and the subs will get like 50rms each, just get an ap1500
c'mon now, if i was shooting an 8 year old, it wouldnt be MY 8 year old.
i recently got a Pyle PL1590BL and i was building an enclosure for it tuned to 25 hz. i didn't have any tools to cut a circle so i hit it with a big hammer.
2003 Infiniti G35 Sport Sedan
Build in Progress
Umm lets see, the amp will not push out enough power, only has a 30 amp fuse. You should give us a budget we will put a decent system together.
Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell
Kenwood H/U
1/0 wire,
136 amp alt 200 ah batteries 12.7 daily
2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts
Mb quart 125.4 wired to 4 aura 6's
3.6 cube box tuned to 36 plays down to 23hz
$400 from taxes figure whats left over i can get ina few weeks or so (part-time min.wage job SUCKS!!!)
where did you get 3000 watts from? alls i see is an amp that outputs no more than 300rms and a subwoofer that can handle 300rms. mind you they arent even fully compatible since you cannot bridge a 2 channel at 2 ohms, only 8 ohms, and then the subwoofer will receive like 100 watts if that.
heres a combo for you
Skar audio vvx-12, same designer from sundown, get the d2 version if you are getting 1. if you are getting 2, get the D4
http://www.skaraudio.com/index.php/products.html
for one subwoofer
http://www.caraudiodeals.com/audiopipe-ap10001d-p-3465.html
for two subwoofers
http://www.caraudiodeals.com/audiopipe-ap15001d-p-1452.html
wiring kit for either amp
http://www.knukonceptz.com/productDetail.cfm?prodID=KOL-AK4
for one subwoofer
for two subwoofers
Good job Kranny! Nice set-up right there! :drink40:
My POS Bass machine-
2003 Hyundai Santa Fe on some shitty 22's
Bed Liner Paint Job-Pioneer AVH 3200DVD
4 DAD BD series 15's in a 4th Order (Bassheads ENT Design)
4 Arc Audio XDI2000.1 for the woofers
6 Cadence CVL68MBX 6.5's-Cadence CVL88MBX 8's-6 Cadence XT20 Supertweeters
2 Arc Audio KS300.4's for mids and tweets
1 Arc Audio ALD 10v Line Driver
All Audiotechnix Power wire
1 DC Power 270XP High Output Alternator
1 XS Power D3400 up front....6 XS Power D3100's in the rear
Air Lift 1000 Bags in rear to help with suspension
If your still reading this GFY.......
for one subwoofer
for two subwoofers
*bows* a-thank you :)
wanting to still go with 6 12's
6-12's =209.85
leaves 200 for an amp/amps
i doubt you will even be able to fit those. you would need a 10 cubic foot box. dont waste your money. one of those vvx's can handle the amount of power that practically 4 of those Hfi's can handle. you can get louder with less woofer. im just trying to look out for you man.
  • Who's Online   0 Members, 0 Anonymous, 8099 Guests (See full list)
