i have a 2door tahoe that i am going to be running 2 btl 15's my outter box specs are 48w x 171/2t x 20d and i need help with the port . the sub are going to be facing up and the port facing back towards the tailgate.Im running a memphis 4kw and is there any suggestions on an alt and what amp to run? this is my daily so i am open to any ideas about anything. thanks
most people on here will suggest an iraggi alt
im not an expert on it but iraggi is the alt to look at
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
This an electrical Question and will be moved accordingly, but yeah, look into the irragis
ok ill look into them for the alt ,but i also need some ideas on the port for my box as well if anyone can help plz!
the re box calculator is ur best friend
http://reaudio.com/speaker_box/LPort_Box_Calc.html
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
u can put the port in between the subs as long as it has the same specs as wut the box calculator gave u
and if the port is longer than the box u can make the port go in opposite L directions
i can give a pic if u give me the dimesions of the port
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
so do i put the specs of half my box in to get one side of the port ? yeah ur help would help alot thanks
i have a 2door tahoe that i am going to be running 2 btl 15's my outter box specs are 48w x 171/2t x 20d and i need help with the port . the sub are going to be facing up and the port facing back towards the tailgate.Im running a memphis 4kw, i am open to suggestions on anything. thanks
sorry im trying to get my port dimensionsfor this box im still trying to learn how th figure ports havent got it yet as u can see lol
  • Who's Online   0 Members, 0 Anonymous, 303 Guests (See full list)
