dewey Posted September 5, 2007 Report Posted September 5, 2007 i have a 2door tahoe that i am going to be running 2 btl 15's my outter box specs are 48w x 171/2t x 20d and i need help with the port . the sub are going to be facing up and the port facing back towards the tailgate.Im running a memphis 4kw and is there any suggestions on an alt and what amp to run? this is my daily so i am open to any ideas about anything. thanks Quote
IH8PunkRok Posted September 5, 2007 Report Posted September 5, 2007 most people on here will suggest an iraggi alt im not an expert on it but iraggi is the alt to look at Quote -Matt2005 Dodge Magnum RTJVC KD-AVX1 2 PPI S580.2 Obsidian Audio ST1 Horn Tweeters PRV 8MB450s Audio Legion 3500.1D 2 RE MT 18s 360 ah LiFePO4 BatterySHCA 2/0 155.2 @ 29 hzKicker CVR 15's buildDD 3512e buildMini T-Line Build(6) 8s BuildNightshade 15s Wall BuildMagnum AB XFL 12s BuildNewest Magnum Build
roscoe1129 Posted September 5, 2007 Report Posted September 5, 2007 This an electrical Question and will be moved accordingly, but yeah, look into the irragis Quote Some people need a sympathetic pat... on the head...with my hammer Scientia est Vox "In Nomine Patris et Filii et Spiritus Sancti" DONT BE AFRAID TO USE THE SEARCH BUTTON!!! SMD SUPER BUYER/SELLER
dewey Posted September 5, 2007 Author Report Posted September 5, 2007 This an electrical Question and will be moved accordingly, but yeah, look into the irragis ok ill look into them for the alt ,but i also need some ideas on the port for my box as well if anyone can help plz! Quote
IH8PunkRok Posted September 5, 2007 Report Posted September 5, 2007 the re box calculator is ur best friend http://reaudio.com/speaker_box/LPort_Box_Calc.html Quote -Matt2005 Dodge Magnum RTJVC KD-AVX1 2 PPI S580.2 Obsidian Audio ST1 Horn Tweeters PRV 8MB450s Audio Legion 3500.1D 2 RE MT 18s 360 ah LiFePO4 BatterySHCA 2/0 155.2 @ 29 hzKicker CVR 15's buildDD 3512e buildMini T-Line Build(6) 8s BuildNightshade 15s Wall BuildMagnum AB XFL 12s BuildNewest Magnum Build
dewey Posted September 5, 2007 Author Report Posted September 5, 2007 the re box calculator is ur best friendhttp://reaudio.com/speaker_box/LPort_Box_Calc.html ok but i want the port in the middle of the box how would i transfer the specs to the middle or could some just give me the specs this sh*t is confusing Quote
IH8PunkRok Posted September 5, 2007 Report Posted September 5, 2007 u can put the port in between the subs as long as it has the same specs as wut the box calculator gave u and if the port is longer than the box u can make the port go in opposite L directions i can give a pic if u give me the dimesions of the port Quote -Matt2005 Dodge Magnum RTJVC KD-AVX1 2 PPI S580.2 Obsidian Audio ST1 Horn Tweeters PRV 8MB450s Audio Legion 3500.1D 2 RE MT 18s 360 ah LiFePO4 BatterySHCA 2/0 155.2 @ 29 hzKicker CVR 15's buildDD 3512e buildMini T-Line Build(6) 8s BuildNightshade 15s Wall BuildMagnum AB XFL 12s BuildNewest Magnum Build
dewey Posted September 5, 2007 Author Report Posted September 5, 2007 u can put the port in between the subs as long as it has the same specs as wut the box calculator gave uand if the port is longer than the box u can make the port go in opposite L directions i can give a pic if u give me the dimesions of the port so do i put the specs of half my box in to get one side of the port ? yeah ur help would help alot thanks Quote
dewey Posted September 5, 2007 Author Report Posted September 5, 2007 i have a 2door tahoe that i am going to be running 2 btl 15's my outter box specs are 48w x 171/2t x 20d and i need help with the port . the sub are going to be facing up and the port facing back towards the tailgate.Im running a memphis 4kw, i am open to suggestions on anything. thanks Quote
dewey Posted September 5, 2007 Author Report Posted September 5, 2007 so do i put the specs of half my box in to get one side of the port ? yeah ur help would help alot thanks sorry im trying to get my port dimensionsfor this box im still trying to learn how th figure ports havent got it yet as u can see lol Quote
