ok so i baught an amp from my friend and before i baught it i had him play his subs with it to see if it worked... it did, so i baught it and then i hooked it up in my car. itll turn on but the channels won't put out any power, is this because of th rcas? the protect light isnt on
18" Sundown Zv4 D2
JL 1000/1 V1
XS Power D3200
more info on the amp/setup
check rca's at both the amp and deck-
make sure your sub is wired properly you (could have been excited n skipped something)
R.I.P!
(Nov-29-2009)
92 explorer
current build
amp - JL Audio e1200
sub - 12" SVC 4ohm pioneer
alpine deck
i have taken the sub out of the box and re hooked it up tried all the + - on the amp ive turned the gains all the way up put em in the middle and lowest ive changed the filters from off to high to low, turned bass boost on and off and i cant think of anything else to try to fix it
EDIT: ive also went into the alpines menus or w/e u wanna call em and turned the subwoofer on and off and turned the subwoofer up in the equalizer
18" Sundown Zv4 D2
JL 1000/1 V1
XS Power D3200
you sure you got the rcas in the right input haha
R.I.P!
(Nov-29-2009)
92 explorer
current build
alpine deck
are you sure the speakers even work? have you tried new rca cables?
i had the sub hooked up in my room on my surround sound, and the cd player only has 1 output and it says subwfr next to it
18" Sundown Zv4 D2
JL 1000/1 V1
XS Power D3200
  • Who's Online   0 Members, 0 Anonymous, 532 Guests (See full list)
