still dont know ohm load, but he definitely should make sure its no less than 1 ohm, so with 4, and im thinking dvc 4 ohm, he should wire them to 2 ohms, especially so he doesnt try to get too much from his electrical, unless he plans to do the big 3 (should do anyways), upgrade bats(he has one already), and maybe an alt
it dpeen ds on how many subs you have at what impedance
dvc 4 ohm subs in which case you have 3 can be run at 2.67 and 6, maybe another configuration
http://www.the12volt.com/caraudio/woofer_configurations.asp?Q=3&I=42#results <---wiring diagram for 3 dvc 4ohm subs
dvc 4 ohm subs in which you have 4 can be ran at .5, 2, and 8 ohms
http://www.the12volt.com/caraudio/woofer_configurations.asp?Q=4&I=42#results <wiring diagram for 4 dvc 4 ohm subs
now i guess i should ask are they single voice coil or double voice coil
either way unless you have good electrical you dont want to drop under 1 ohm, and your best bet would probably be 2 ohms
so 4 wired to 2 or 3 wired to 2.67 most likely id say
the mrp m 2000 of alpine costc 440$(dolars)
and it gives you 1500WRMS at 4 ohms and 2000wRMS at 2 ohms...
2010 Chevrolet Cruze
Radio --- pioneer mvh-200vbt
Front/back --- alpine type s 6.5"
Sub Control --- Pac LC1
Sub Amp --- GZPA 1.4K
Sub --- GZNW 15XSPL D1
Battery - GZBP 12.2500X
