Specs are 13.5ft w/ 192.5in of port tuned to 32hz. The measurements are 19"h x 49"w x 37"d. It'll hold a pair of FI BL 18s powered by a pair of RF T1Ks.
Posted Image
Posted Image
Clamps are like a couple extra sets of strong hands.
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
My 2-yr-old in the port.
Posted Image
Posted Image
Test Fit
Posted Image
Posted Image
Second baffle and lines drawn out.
Posted Image
Posted Image
Posted Image
That's it for today. Tomorrow I'll cut out the mounting holes, flush the port, and roundover the box edges. Then I'll see about some joint bracing. The subs are on their way with an expected delivery date of Thursday July 19th.
looks great, I just built a new box and its having a hard time fitting in my trunk =\! gotta do some alterations =]
15" re sx 4.1 cub at 33hz box by coolwazabi
I like it. Looks like a bigger version of the one that I just did. Generally the same amount of power. I am curious to see how yours turns out. Looks good so far.
I like yours as well. So when are we gonna see some vids of those REs in action? I'm going frantic waiting on my subs to get here. Its okay because even though it looks like the box is almost done there is still a lot of little things to be done.
Try using a roundover bit on the box edges and removing any matt or carpet from the trunk floor. It helped last time I had trouble squeezing a box into a trunk.
Today's work.
Routing the sub holes.
Posted Image
Posted Image
Second baffle.
Posted Image
Finally finished.
Posted Image
Next is the flush bit for the port.
Posted Image
And now the roundover bit for the entire box and inside the port.
Posted Image
Posted Image
Last, a little hand sanding to smooth it out.
Posted Image
Posted Image
Posted Image
Tomorrow I'll be mounting the amps and running the speaker wire. When my subs get here I want to be able to screw them in a slide the box into the truck.
looks like a pretty nice build. it should pound!
The New - 2002 Acura Rsx (work in progress)Eclipse AVN7000Eclipse 4 Channel4 Polk Audio Db 6.5 (soon to be changed)T500.1Punch 3 15"- The (old) System - 94 GMC Sonoma Ext. CabH/U - Pioneer Avic D3Eclipse 4 Channel Amp2 MB Quart DUA 216 6.5 components2 Polk Momo 4x10s1 RF Power T5001bd2 RF P315D4's 5 cubes net @ 35hzPowermaster D1200 Battery
so what's the box tuned to?
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
nice box build...but im curious of why you didnt do the box CRX style...
2007 Chevy HHR LT
UNDER CONSTRUCTION
1st Place Loud N Low 2010 MWSPL Finals
3rd Place Xtreme 3 2010 MWSPL Finals
  • Who's Online   0 Members, 0 Anonymous, 2412 Guests (See full list)
