Weird clicking noise coming from subwoofer
DylanH
Alright so I just picked up this 15. Its for a temp system its a Planet Audio Big Bang 15. Well I just got it in and now when it plays it makes this click noise. It basically sounds like the dust cap is loose. But it seems to be on there fine.
Edit:Anyone have any ideas on what it could be? Or what to check? It does it at any volume in or out of the box. But if I put a little bit of pressure on the cap. Like all I have to do is put my hand on it and barely touch it. I can't hear the noise.
http://www.youtube.c...er/SmallTownSPL
2002 Chevy Blazer
Substage: Shhh, its a secret ;)
Mids and Highs: Stock-Going to change soon
Amp:MTX 92001
Wire:1/0 Welding cable
Electrical:Stock
http://www.stevemead...__fromsearch__1
I hope she was meaning that to you. Any who.... You dont say you wanna have dinner in the first damn post. talk to her first. I say find out if the status was torwards you..
Here try this...
"Hey hows it going :)( notice smiley face makes everything better ) I saw your status. "You are far from usual".... So is my dick... Wanna Fuck tommorow???"
Or send her message saying "hey" she replies back "hey" when this happens reply Wanna fuck (INSERT ADDRESS HERE)
Quote of the SPL Creed ; back in the day my girlfriend gave me a choice between her and my love for car audio, I told that bitch I've made harder decisions at the Coke machine. :)
Both coils read 4 ohms on the dot. When wired checked it with a dmm and it read 2 ohms like it supposed to. Not sure what to check. I shook the sub a little just to see if I could hear anything rattling didn't hear a thing. When I push on the cone a little it doesn't make a sound. I'm running out of ideas.
2002 Chevy Blazer
Amp:MTX 92001
Electrical:Stock
Here try this...
Anyone have some ideas?
2002 Chevy Blazer
Amp:MTX 92001
Electrical:Stock
Here try this...
had the same exact problem with my subs when I put em in last week man I was like wtf is goin on because everything seemed fine and it wasn't any of the problems like you listed....It was actually because my subs were leaking air because they didn't have an airtight seal...Try what I did and tape off all around your sub and see if the noise stops if it does then you just need to seal it better which I did by takin the subs out, putting weather stripping down, and puttin em back in
Yea probly air leak.....................
  • Minivanfromhell -- Proud Member of Shut It Down Boyz & GEORGIA CAR AUDIO
Pioneer DEH-3400-UB
Vega 65 cs & 1" tweets & T3 4" coax in Front
1- Dual 300 with an AQ sticker
2-AQ sdc2.5 12's
1- AQ 1200D.1
Monster Cable RCA's
Monster Cable 4-awg
Custom 4 th order box ( by DBC )
Crescendo FT1's in rear- 1/0 Big Three
Opti Blue top in back for Mono Amp
Stinger Power dis. block
125 amp breaker at front batt.
Stock Alt.
Not an air leek.
I had this same exact problem on my 2nd RE audio XXX.
Your tinsels inside of the spiders are arching.
To test and prove this,
Pull the sub out and free air it, watch the spider for sparks/arching
Keep me updated
'08 Chevy Cobalt coupe 2.2 base model trunk build:
2 9512iSC flatwound alum 1.5 coils
-extra 9500 spider pack
-8" platinum carbon dustcaps
1 DD Z1 (.375ohm nominally daily)
3g31 AGM
320a Ohio Gen alt
1 DD S4 4 channel
4 VO-M8v1's (holes cut for 3rd pair)
2 CS 6.5's
2 VO-B1's
Sony XAV-601BT
all Knu Krystal RCA's
Cadence 7band EQ
______________________
148.3db @ 32hz (burp)
148.4 @ 37 & 38hz (burp)
146.xdb 90sec average (center windshield)
It may be the tinsel leads hitting the bottom of the cone, this makes a snapping sound when playing but won't make any noise when pushing the cone in or when shaking it. pull the sub out and look at the leads if they are not sown in they maybe the culprit.
Tinsel slap..........i forgot about that, I had a REsex 12 that did that.............never seen the arcing at the spyder before, but i'm sure it could happen..........
Pioneer DEH-3400-UB
2-AQ sdc2.5 12's
1- AQ 1200D.1
Monster Cable RCA's
Monster Cable 4-awg
Stock Alt.
loose dust cap
tinsel leads
cant think of anything else
edit: air leaking would sound like puffing, not clicking
loose dust cap
tinsel leads
That sound you hear starting at about 0:08 is due to air leakage..
  • Who's Online   0 Members, 0 Anonymous, 4005 Guests (See full list)
