My Q1-3500D.1
Impalalpine
Came in the other day.
6011975c-c8e3-4202-9687-f7d6727dbb8f_zps
774848_601630296520865_412576969_o_zps8c
Build's consist of:
2004 Chevy Impala :
Pioneer--------------------- DEH-X8600bs Soundqubed/AQ------ Q4-120
Rockford Fosgate---- Punch-500.4
Soundqubed/AQ----- Q1-3500D.1 Alpine----------------- 6.5's & 6x9's
Subs: TBA All Knukonceptz and SHCA wire and rca's
Home Music Setup
(4) Soundqubed HDS200 15's in two separate 15.5 cubic foot enclosures tuned to 31 hrz --- XM radio hardwire
Updates coming all the time on both builds
n8ball2013
"bullshit. Everything fits. If you cut enough."
Hope your electrical is ready.
DD M4
Rockford Fosgate P500-4
SoundQubed HDC415 w carbon fiber cap
2 Rockford Fosagate T1675-S
XS Power D3400 Under Hood
XS Power D5100 in rear
Michael Singer 200A Alt
Build Log: http://www.stevemeadedesigns.com/board/topic/153901-2012-veloster-update-842013-wall-build-4-15s/
Sick amp
01 focus se
110 amp alt
Big 3 sky high and stinger hpm ofc 1/0
Super start platinum AGM (starting)
2 runs of 1/0 Execution audio front to back
Kenwood double DIN DDx271
A pillars- orion 4" super tweeter and 2-1" alpines.
Orion xtx 64 in the front doors
2:1 4th order bandpass
Sealed off trunk
Digital designs deadener on roof/ rear deck
Orion hcca 12s (black coils)
Orion xtr3700.1
Orion xtr250.2 mid/highs
All sky high 1/0 in trunk dual runs(power/ground)
Sky high dual 1/0 inputs
2 xs power D3100 in back
Sky high batt blocks
Rose audio batt blocks
Stinger volt meter
All sky high 1\0 fuse and holders
Db link remote/ rca
With your 3400 and 3100 your doing alright on voltage? With two strapped?
Edit: It will be at 4 ohms for the moment
Build's consist of:
2004 Chevy Impala :
Home Music Setup
n8ball2013
Id like to know also..
Team Subsonic Lows
Get your garbage EMF products of my amp bitch
Man....it makes a nice work bench ;)
So, currently I have 2 AQ 3500's strapped at 1 ohm and each amp is seeing a .5ohm load. Surprisingly I have not had any issues yet running this massive load on my relatively weak electrical. I most definitely plan on adding at least 1, if not 2 more D3100's to the build to help cushion the load though. I have not ran it full tilt for very long and I think if I did it may dip pretty low and could throw the amps into protect.
With just 1 amp at .5 ohm, a 200 amp alt, D3100 and D3400 were plenty enough to keep the amp alive. 4 ohms will give you much better efficiency so you should be fine.
DD M4
  • 1 month later...
Build's consist of:
2004 Chevy Impala :
Home Music Setup
n8ball2013
  • Who's Online   1 Member, 0 Anonymous, 906 Guests (See full list)
