RareBreed Posted January 19, 2015 Report Share Posted January 19, 2015 I just recently installed a new system and my doors are flexing like crazy. I have a 99 tahoe and the rear barn doors flex too much, not worried about the flex itself as much just the noise the doors make as there about to jump off the hinge. im just curious if anyone has did anything to reduce this besides sound deadener. Link to comment Share on other sites More sharing options...
MaxMays Posted January 20, 2015 Report Share Posted January 20, 2015 Only way to really "reduce" flex is by adding some form a mat to stiffen the metal. There are ways of "absorbing" the vibrations and reducing noise. And that would be to simply wedge soft objects such as a blanket or some form of foam inbetween the vibrating parts. Problem with putting blankets in your doors, is that it will eventually absorb moisture, and now you have wet blankets in your door which will start to getting moldy and nasty, on top of possibly promoting rust. Generally, the door cards themselves as well as the window slider mechanics are what cause the most amount of "noise". Other than actually matting down everything on the backside of the door card. You really dont have much options besides deadener, or the spectrum sludge that Second skin offer. Link to comment Share on other sites More sharing options...
jk13 Posted January 20, 2015 Report Share Posted January 20, 2015 99 Tahoe rear barn doors…replace hinge pins and bushings, replace or at least properly adjust all the latches, and replace the rubber seal on the truck side. That should help a ton. Mine are shot and so are most others that I see. Grab the top edge of the door and pull back to test--just about guarantee there's some movement there if those parts have never been replaced. Also add sound deadener. Static drops are my bag. Link to comment Share on other sites More sharing options...
RareBreed Posted January 20, 2015 Author Report Share Posted January 20, 2015 Thats pretty much whats making the noise, not door internals , but the barn doors themselves at the top, like there jumping off the latch and slapping togeather, hinges dont seem loose but ill check that and the weather stripping, its a bummer really, feel like i cant enjoy my new system like i should be.. i appreciate the help guys, ill let you know what i find out Link to comment Share on other sites More sharing options...
RareBreed Posted January 20, 2015 Author Report Share Posted January 20, 2015 The hinge pins are not loose at all, it seems as if the lock mechanism and the latch itself is whats making the noise, i might try the weather seal and fee if that will put more pressure to keep the door stiffer at the latch Link to comment Share on other sites More sharing options...
Aj11 Posted January 23, 2015 Report Share Posted January 23, 2015 weather stripping! my doors flap open like a retired porn star running into the wind! i got some nice thick weather stripping, put it around the door and car. worked like a charm! now they don't flap open, make noise... nothing! actually gained a Lil because now air isn't escaping threw the doors. did the same thing for my trunk. jvc deck stinger 1800 front hc 2000 kinetic rear 2 runs of 1/0g big 3/4 ct 60.4 2 ct 1400.1 ct EXO 15 d1 lots of deadner type r comps front stage 6 kicker tweets rear stage lots of great stuff coming soon ho alt more bats ct comps for front stage more deadner sweet amp rack lots of L.E.D lights new deck (thinking 80 prs, or flip out) Link to comment Share on other sites More sharing options...
RareBreed Posted January 23, 2015 Author Report Share Posted January 23, 2015 Ill try it man thank you, i wrapped some take around the striker on the barn doors so it wasnt metal on metal, and that helped with some of it Link to comment Share on other sites More sharing options...
Aj11 Posted January 23, 2015 Report Share Posted January 23, 2015 the harder your doors are to shut the better it works. for a month i had this terrible rattle coming from the back of my car. i thought it was the internals of my rear doors. until one day i had my Buddy upfront, Lil bro in the back and his friend back there. I'm a few seconds into the demo/drive and i hear my Lil bro go "holy shit!" i turn down the beats to hear him. he tells Me he can see daylight coming threw my door. turn back up and then realized it was both doors. they were opening allot! cost like $12 bucks in weather stripping to fix it. jvc deck stinger 1800 front hc 2000 kinetic rear 2 runs of 1/0g big 3/4 ct 60.4 2 ct 1400.1 ct EXO 15 d1 lots of deadner type r comps front stage 6 kicker tweets rear stage lots of great stuff coming soon ho alt more bats ct comps for front stage more deadner sweet amp rack lots of L.E.D lights new deck (thinking 80 prs, or flip out) Link to comment Share on other sites More sharing options...
bigsausagepizza Posted January 23, 2015 Report Share Posted January 23, 2015 weather stripping! my doors flap open like a retired porn star running into the wind! i got some nice thick weather stripping, put it around the door and car. worked like a charm! now they don't flap open, make noise... nothing! actually gained a Lil because now air isn't escaping threw the doors. did the same thing for my trunk. Where do you put the weather stripping? I would like to secure up my hatch a bit, but it already has a bit seal all the way around. Do you apply on top of the seal, or around the outside/inside of it? 2008 Subaru WRX STI K&N Typhoon Intake Invidia Polished Stainless 3" turbo back with cat Cobb Accessport Dyno tune from Kaizen Tuning 320awhp 330ft-lb awtq MTX 421D Sub amp American Bass SQ900 Highs/Mids amp Sundown Audio SD-2 10 D4 JL Audio XR653-CS 3-way Components 3sixty.2 Second Skin Damplifier Pro Custom fiberglass wheel well enclosure Transmission Line quasi-floor enclosure http://www.stevemeadedesigns.com/board/forum/13-member-rides-builds-show-off-your-whip-show-off-your-system/ Bill Fitzmaurice TLAH line-array hifi towers 9 Goldwood 4" mids (each) 12 Goldwood 1/2" tweeters (each) NAD 1020 Preamp MiniDSP 2x4 Balanced processor Thorens TD166mkII Turntable Hafler DH-200 Amplifier http://www.stevemeadedesigns.com/board/topic/192638-line-array-hifi-tower-build/ https://www.facebook.com/HolyMountainGlass Link to comment Share on other sites More sharing options...
Aj11 Posted January 23, 2015 Report Share Posted January 23, 2015 i put it all the way around the outside of the door where the doors stock weather stripping touches the car.then i applied more to the car where the new weather stripping from the door would touch. be sure not to leave a gap! water will seep in if you don't have a good seal. jvc deck stinger 1800 front hc 2000 kinetic rear 2 runs of 1/0g big 3/4 ct 60.4 2 ct 1400.1 ct EXO 15 d1 lots of deadner type r comps front stage 6 kicker tweets rear stage lots of great stuff coming soon ho alt more bats ct comps for front stage more deadner sweet amp rack lots of L.E.D lights new deck (thinking 80 prs, or flip out) Link to comment Share on other sites More sharing options...
