alibaba Posted October 26, 2016 Report Share Posted October 26, 2016 I farted once and did a <script data-cfhash='f9e31' type="text/javascript">/* */</script>, it was in a hatchback wall! funniest shit ive read all day 06 Envoy 250a ALT 2x 2400 kinetiks USX65KV1 w/ parallel bridged mosfets 2200rms @ 1ohm @13v powering 1 Orion hcca122 Taramp HD2500 for mid range 4xPioneer 6x9's 2x 1" Pioneer tweets Link to comment Share on other sites More sharing options...
walrus salesman Posted October 26, 2016 Author Report Share Posted October 26, 2016 I have noticed sealed boxes seem to carry louder out of the car than ported, I think because the cabin acts like the ported section of a 4th order. IDK Very interesting... I'll have to do some testing when I get My new car and subs Link to comment Share on other sites More sharing options...
walrus salesman Posted October 26, 2016 Author Report Share Posted October 26, 2016 I have noticed sealed boxes seem to carry louder out of the car than ported, I think because the cabin acts like the ported section of a 4th order. IDK But wouldn't a ported box make the cabin act like the port of a 6th order ? Link to comment Share on other sites More sharing options...
walrus salesman Posted October 26, 2016 Author Report Share Posted October 26, 2016 Yeah hatchbacks and tiny cars are extremely loud inside, my friend did a 152 or I believe a 151 at 29 hertz on 3,000 watts rms with a single skar 12 in a trunk wall , giant aeroport tuned low, Scion FR-S. Outside you could barely hear anything even with both windows down 151 at 29 Hz on a 12" (Skar) sub, on 3k ? I can' believe it ! In a trunk ? That is incredible ! Did you want to write 131, or maybe 141 ? Yeah sorry I got the information mixed up, 152 with 2 subs, 5k amp, giant aero, and burp score. He did a 47 with the single sub, same box, same amp Link to comment Share on other sites More sharing options...
ShadeTreeMechanic Posted October 26, 2016 Report Share Posted October 26, 2016 The car was a 1976 Ford Granada. I still have it but the system is out of it because the quarters rusted through and the box started getting wet so I took it out. The first box was 4 cubes each. Took up the whole trunk and the subs were right at the trunk lid. That was ok but made a lot of rattles that I couldn't get rid of. So I built a new box 3 cubes each pointed forward at an angle like more than 45 degrees kind of down and forward. I made a tunnel for it to mate up to that went up behind the back seat. I cut the brackets off of the seat back so I could pull the bottom of it and lay it flat. You could see the subs through the tunnel if you tried. Kicker 6x9s and two kicker 8s in the rear deck. Polk separates in the front door. A punch 200 on the c15s. Rated 400wrms bridged at 4 ohms. A punch 100 on everything else. ploks and 6x9s parallel. 8s bridged tri mode. The punch 100 wasn't rated for all that but it never got hotter than the 200. It sounded good and balanced but a little bass heavy. I put a radio shack EQ in the trunk because it had a 35hz band that of course I pushed all the way up. Driving down the back roads one day I saw some guys standing at the end of their driveway. Years later I happened to meet one of them. He said that they heard the booming coming down the road and they were going to stop my car. Until I got close enough that they heard that I was booming to led zeplin. lol I had it set so anything would boom. The Eagles, Lynrd Skynrd, Bad Company, Easy e, Super Cat, Megatron Crushing Crew etc. lol 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon) Link to comment Share on other sites More sharing options...
Skullz Posted October 26, 2016 Report Share Posted October 26, 2016 Higher sub frequencies will sound as if they are louder than they really are and carry farther, as the frequency lowers, so does the sound outside the car, but that does not mean it doesn't travel as far, it just means your not able to hear it. Larger subs will do the same thing allowing them to project the loudness farther out than smaller subs will, and in conjunction with a tuning of 40hz to 60hz they can be heard from really long distances, as i said before but eluded to the details, when you have a slightly larger than optimal box with higher tuning and larger subs and power you can get much louder outside of a vehicle regardless of brand. 01 Ford focus ZX3 Pioneer AVH-X491BHS PPI PC 4800.2 Morel Maximo 6.5" x2 Link to comment Share on other sites More sharing options...
Knocker Posted October 26, 2016 Report Share Posted October 26, 2016 I think the car at the gas station with the Xplods possibly sounded louder because many gas stations have roofs over the pumps and the bass may have been reflecting back down at you from the roof. The loudest vehicle I've ever heard oudside was a minitruck back in the late `80's in the downtown area of Westwood, CA... Nothing but giant glass high rises all around. We could hear it from blocks away. No idea what he had inside but I'm sure if we had been in an open field it wouldn't have been nearly as impressive. Link to comment Share on other sites More sharing options...
Jessica Posted October 26, 2016 Report Share Posted October 26, 2016 The car was a 1976 Ford Granada. I still have it but the system is out of it because the quarters rusted through and the box started getting wet so I took it out. The first box was 4 cubes each. Took up the whole trunk and the subs were right at the trunk lid. That was ok but made a lot of rattles that I couldn't get rid of. So I built a new box 3 cubes each pointed forward at an angle like more than 45 degrees kind of down and forward. I made a tunnel for it to mate up to that went up behind the back seat. I cut the brackets off of the seat back so I could pull the bottom of it and lay it flat. You could see the subs through the tunnel if you tried. Kicker 6x9s and two kicker 8s in the rear deck. Polk separates in the front door. A punch 200 on the c15s. Rated 400wrms bridged at 4 ohms. A punch 100 on everything else. ploks and 6x9s parallel. 8s bridged tri mode. The punch 100 wasn't rated for all that but it never got hotter than the 200. It sounded good and balanced but a little bass heavy. I put a radio shack EQ in the trunk because it had a 35hz band that of course I pushed all the way up. Driving down the back roads one day I saw some guys standing at the end of their driveway. Years later I happened to meet one of them. He said that they heard the booming coming down the road and they were going to stop my car. Until I got close enough that they heard that I was booming to led zeplin. lol I had it set so anything would boom. The Eagles, Lynrd Skynrd, Bad Company, Easy e, Super Cat, Megatron Crushing Crew etc. lol i had a 79 and did an IB behind the rear seat with 2 mtx road thunder 12's it was not loud. lol Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13 Link to comment Share on other sites More sharing options...
walrus salesman Posted October 26, 2016 Author Report Share Posted October 26, 2016 The car was a 1976 Ford Granada. I still have it but the system is out of it because the quarters rusted through and the box started getting wet so I took it out. The first box was 4 cubes each. Took up the whole trunk and the subs were right at the trunk lid. That was ok but made a lot of rattles that I couldn't get rid of. So I built a new box 3 cubes each pointed forward at an angle like more than 45 degrees kind of down and forward. I made a tunnel for it to mate up to that went up behind the back seat. I cut the brackets off of the seat back so I could pull the bottom of it and lay it flat. You could see the subs through the tunnel if you tried. Kicker 6x9s and two kicker 8s in the rear deck. Polk separates in the front door. A punch 200 on the c15s. Rated 400wrms bridged at 4 ohms. A punch 100 on everything else. ploks and 6x9s parallel. 8s bridged tri mode. The punch 100 wasn't rated for all that but it never got hotter than the 200. It sounded good and balanced but a little bass heavy. I put a radio shack EQ in the trunk because it had a 35hz band that of course I pushed all the way up. Driving down the back roads one day I saw some guys standing at the end of their driveway. Years later I happened to meet one of them. He said that they heard the booming coming down the road and they were going to stop my car. Until I got close enough that they heard that I was booming to led zeplin. lol I had it set so anything would boom. The Eagles, Lynrd Skynrd, Bad Company, Easy e, Super Cat, Megatron Crushing Crew etc. lol That's awesome Link to comment Share on other sites More sharing options...
walrus salesman Posted October 26, 2016 Author Report Share Posted October 26, 2016 I think the car at the gas station with the Xplods possibly sounded louder because many gas stations have roofs over the pumps and the bass may have been reflecting back down at you from the roof. The loudest vehicle I've ever heard oudside was a minitruck back in the late `80's in the downtown area of Westwood, CA... Nothing but giant glass high rises all around. We could hear it from blocks away. No idea what he had inside but I'm sure if we had been in an open field it wouldn't have been nearly as impressive. Yeah you might be right, LOL my car is only loud under roofs or parking garages Link to comment Share on other sites More sharing options...
