2002 4runner - 16 12s 4th order
So about a month ago I received a lot of help with a clamshell for 16 12's, infinity 1262w's. I ended up with a bad design and a badly built box. 2000LaDe was awesome and design and sketched up a 4th order for me and after some research this is what i ended up building. Everything I'm posting now was done in the last 3 days or so. I just graduated and have some free time before the real world kicks in.
16 infinity 1262w's and a sundown 3500
5 sheets of 11 ply birch from menards
space heater for the garage cuz Iowa is f*ck'n cold
I added a bunch of wiring between my 2 rear d3100s. note: I've been in car audio for 4-5 months now and have been adding random wiring along the way. yes it is ugly as f*ck. yes I should clean it up. but it works for now :shrug:
be nice :P
in there is 3/0 welding, kicker hyperflex, stinger hpm, the monster pro stuff that's so damn stiff you could probably use it for bracing a box and db link elite soft touch.
first thing I did was bafflz
externals ended up being 36.5 wide 33 tall 61 depth
bracing is 1 1/4" dowels
top went on
primer
hit 70k miles!!!! wohooo
mounting the subs was an absolute pain in the ass. did it after lifting weights too T_T
very back of the box is roughly 6 inches wide
port size was supposed to be 19x19 but i noticed that the port would cut off the front sections of the box so i had to shrink it down. ended up being 31.5 x 7.5. winisd tells me that's 45 hz tuning. port velocity/vent mach/whatever it's called .04
removable so I can actually tweak with the box instead of having to build a new one if I eff it up.
hiiiiiiii
2002 4runner - buncha speakers n amps n shit (gone)
1994 astro - more stuffz
update: pretty sure all the pic links in the logs are broken lol.
ma slop garb build log
16 12's 4th order
4runner rebuild in progress
clickkk meeeee!!!! 4 18's 6th order
UBL - clicky
http://www.youtube.com/yyj11589
lots of hater kids here. Pay no attention, they just want 89,000 watt subs for 3.50
If you would have put a dc dustcap on it and called it lv your mom, they would all be in love
so apparently there's a limit on how many images you can post so continuing..
subs were mounted before the box went in. loading it into the car should not be a one man job...
that's all I have for now. it's late, cold and snowing right now. I listened to it for shortly but didn't want to drive anywhere through the snow. still have to add mids and highs and seal it off.
two things I could use a bit of help on. suggestions on how to wall it off(never done it before). I don't think I'll be able to seal at the b pillar because the seats go past it so sealing at the window? also, i noticed the baffles are still flexing...i'm planning to a couple more of the dowels in between the two baffles and see if it helps. any other suggestions on bracing would be appreciated. comments are nice too ^_^
thanks everyone!
*edit - big thanks to 2000LaDe for the box design. your truck was an inspiration for me to do lotza woofrz :drinks:
hiiiiiiii
16 12's 4th order
UBL - clicky
VIDEOSSSSS!!!!!!!!!!!!!!! :D
very sexy btw lol
(UNDER CONSTRUCTION)
Kenwood KIV-700 headunit
2 18" sundown Z.v3s
13.5^3 wall tuned @ 28hz
SAZ-3500
DC power 270amp alt
JL c2 650
AP600.4
XS 1200 under the hood
XS 3100 in the trunk
1/0 gauge
big 3
25^2ft audio technix
^^ c-fuzzy ur an idiot, my 15" soround is waay bigger cuz its a tall sorround, on top of that I HAVE A BIGGER MOTOR... oh yeah and fuck u suck my dick i got your hoes!
anywhere they want to. They cant hear anyone telling them otherwise. just because its bigger doesnt make it any different. they just piss people off faster and farther away.
very sexy btw lol
thank yoooooo. I'll try and get some vids up soon, still don't really know how it sounds lol. didn't wanna wake up the neighbors. might be 5 days or so until I can. going over to a friends for a while to hang out with people and celebrate ma bday before I get a job.
hiiiiiiii
16 12's 4th order
UBL - clicky
I like :). Yes having 1 baffle u really need more bracing on the back side and on the frontside attaching baffles to eachother. U need at least 1 brace between allege subs. The stronger you make the whole thing the better it will do as far as efficiency goes. Looks good though!
fucking sick bro
________________________________________________________________________
deepsilencer, on 22 Aug 2011 - 17:32, said:
splzx3, on 22 Aug 2011 - 17:27, said:
i had my fun on one of his videos...till he blocked me then i got my mother into it lol after her he closed the comments xD
WTF, I never thought I'd have a conversation about cross dressers and trans-genders on a car audio forum.
1. Double baffle would have helped eliminate the need for more bracing.
2. to wall it off, make cardboard templates to fill the areas between the box and the sides of the car, transfer said templates to cardboard.
Good luck! Looks good! :clapping:
thank you :D
I'll get those in soon then, probably do 4 of them. didn't you just wedge yours in and not drill or glue anything on?
fucking sick bro
thank you too :D this is my first time really worrying about how the setup looks.
One big concern I have is when I do seal it I don't want to mess up the car too bad. I looked through some build logs but didn't see any sealing at the window.
*edit - reason i didn't double baffle was because of space constraints. 4 runners are really really small suvs. that and 2000LaDe's 24 sa-10s on a single baffle didn't seem to have any issues with it. i'm guessing the bracing between the two should solve things.
hiiiiiiii
16 12's 4th order
UBL - clicky
u need 2 get videos up of this bitch asap
  • Who's Online   1 Member, 0 Anonymous, 423 Guests (See full list)
