and PLEASE tell me what the hell is wrong with my Buick........
its a 3100,when I start it,,,,,this is what it does....
In the Vid....I started the car,walked around front and turned on the camera...........after the second time it chugs away....comes back and idles high.........then it runs smooth
http://www.youtube.com/watch?v=89wkgm0phhc
does it every morning when I start it......and every day when i start it after work....
once it chugs,,,,,idles high,,,,chugs,,,idles high............it runs flawlessly after that
My MainMan,My lil Man,Dude,Bubb....My son Memphis @ 3years OldShow'em that car son..........
it sounds like the ecm is "hunting" for an idle. do u hear any vacumn leaks? have u tried cleaning the throttle body and iac solenoid(if it has one)? any check engine light on? last guess would be o2 sensor.
IAC...?
Idle Air Control.
Could be bad Valve or the sensor.
However, there's also:
Throttle position sensor (TPS)
Idle stop solenoid
Idle speed control actuator
EGR valve
Manifold Absolute Pressure (MAP) sensor,
and PCV valve.
All of which can make for an erratic Idle.
http://www.autozone.com/servlet/UiBroker
COOGLE SAID:"bro thats how we got where we are... buy making messes ...... i still learn all the time you just gota be willing to ruck up some shit" "In order to attain the impossible, one must attempt the absurd." ~ Miguel de Unamuno"One machine can do the work of fifty ordinary men, but no machine can do the work of one extraordinary man" -Elbert Hubbard"A proud man can learn humility...but he will be proud of that too" ~I forget who.I'm far from perfect and I know it better than anyone, but I hope to be good at what I do, when I do it...Installs I've done:My Integra: http://www.stevemeadedesigns.com/board/ind...?showtopic=3161The Lexus : http://www.stevemeadedesigns.com/board/ind...?showtopic=1535Law's Maxima: http://www.stevemeadedesigns.com/board/ind...ic=5568&hl=Jeff's 2500HD: http://www.stevemeadedesigns.com/board/ind...ic=5382&hl=Acura RSX-S: http://www.stevemeadedesigns.com/board/ind...?showtopic=3142Z-32 300zx: http://www.stevemeadedesigns.com/board/ind...?showtopic=34602004 Civic 4dr: http://www.stevemeadedesigns.com/board/ind...?showtopic=8190Trunk/Corner Box: http://www.stevemeadedesigns.com/board/ind...c=16036&hl=1969 Chevy C-10: http://www.stevemeadedesigns.com/board/ind...c=20319&hl=Seat-Back AMP-RACK How-to: http://www.stevemeadedesigns.com/board/ind...ic=9428&hl=Bunch of subs still for salehttp://www.stevemeadedesigns.com/board/ind...l=lsn2meboom916"It's game night...we're playin......sex."~Quagmire"When disneyland started it was powered completely by orphan children running on treadmills to generate e-lectrissty…and today, them children are New York Yankees". ~Dale Gribble"Fill it with ice...then pour it up to the top of the ice...& Shut da Fu** up!" ~Urs truly.
yes iac = idle air control. i know on alot of fords they get grimed up and have a problem adjusting the idle. usually if u clean the solenoid it frees up the movement and fixes the surging. not real sure on the gm though!
The first two things I do when a car has problems is check the plugs and change the fuel filter.
Usually checking the plugs will tell you if it's a fuel related problem. If the plugs aren't discolored, then I move on to the next times. It could be a sensor, but without plugging into an ODB it's hard to say.
Have you checked to make sure you pulley's and belt are ok and that the belt isn't slipping?
Edited by str86diesel
2k6 Dodge Ram 2500...CUMMINS POWERED - SOLD
Is the isc motor causing it to go irratic? I had a similar problem in my cadillac and I just disconnected the ISC motor because it had a bad gear and they wanted $150 for a new one and the rebuild didn't come with the gear I needed. Also I would try the Throttle Position Sensor, I replaced that on mine too and it kinda cured the problem for a period of time until the ISC motor completely shit itself. Leaks in the vaccum lines also could cause that.
1986 C20 Suburban
9 American Bass XFL 15's
B2 M1MKII
14v XS Power Batteries
Maxwell Caps
Acoustical energy is free. Electrical energy is not
you havent lived until you've hit a screw with a router.
IAC...?
Idle Air Control.
Idle stop solenoid
EGR valve
and PCV valve.
the bleu one is the idle air control......correct????
Not neccessarily Tim,
Technically it could be any old color and I don't have a shot of your motor at hand-if you could post a shot of the blue sensor in question I could prolly ID it for ya. If it's still oem it could be blue or brown, if it's aftermarket it could be grey, black,silver, etc.
snap a pic of ur engine bay or the spot ur lookin at the blue sensor.
Meanwhile I see if I can dig up some pics of the sensors for ya.
Here this one gives a location for a few of the sensors mentioned, im still lookin for pics.
http://www.autozone.com/shopping/locsSelect.htm
It would be mounted to the side of the throttle body. (if you look at the last link there are schematics)
IAC pic. (looks silver/grey)
http://www.autozone.com/N,15900207/shoppin...peResultSet.htm
some IAC info
http://www.autozone.com/servlet/UiBroker?F...23d800ed109.jsp
Edited by LSN2meBoom916
some IAC info
I meant the one circled in blue....silly.....It is the IAC......but I cannot seem to get the screws out...there is a tube ,which the upper radiator hose connects to...its in the way...
screws..#3 I cannot seem to get
and Im getting REAL pissed off.....
Edited by groundpounder2k2
  • Who's Online   0 Members, 0 Anonymous, 3945 Guests (See full list)
