Adding Two Deka Intimidator G31's In The Trunk
Ok so i plan on adding two new batteries in my trunk. I would like to go with a Powermaster d3100 but they are just pretty damn expensive for my somewhat budget build. So i was gonna go with a Kinetik 2400 used from CA.com but no one is really selling them.
So I decided to go with a Deka Intimidator G31. 1000 CCA not too shabby for the price.
I can get them offline from RemyBatter.com for like $405 shipped or from a local Car Quest dealer for like $401 and I can have it the same day.
How are these batteries for the price and how well do they perform? Ill be running a Crunch GP3000D to a BTL off of it with big three in 1/0 and an Iraggi 200amp alt.
Also will I need these for the batteries?
http://www.remybattery.com/Products/Stud-t...tors__5514.aspx
d3100 is cheaper than the kintek if you can wait till the 19th
DC.jpgDC POWER
Do you have any specs on the D3400? I cant seem to find them anywhere. Weight, size, CCA, deep cycle AGM etc??
75AH, 48lbs, 2000 max amps.
10.25"x6.8"x7"
The Dekas would have a little more researve capacity, but the PM will have a much higher/faster discharge rate which is better for SPL. They will fit better in your ride too.
All the XSpowers are a hybrid audio battery, that means they can be deep cycled, but have amuch higher discharge rate than a conventional deep cycle battery. Of course, they are AGM design.
They are the best, that's why Steve uses them, and that's why we use them ;)
