This is going to be a pretty easy small project and shouldnt take long to finish. Im taking out the rear deck of a chrysler cirrus witch houses two 6x9s and going to make it fit two 10' subwoofers pointed at an angle.
Edited by Street
My Babies
97 2.5 Avenger, 92 5.0 Fox, 97 2.0 Turbo GST Eclipse, 00 2.0 Jetta, 06 GSXR 600, 98 CBR 600, 01 GSXF 600, 93 CBR 900RR
Wilwoods dont slow your car down, they slow the earth down under your car...remember that next time you slam your brakes, you may spill my drink.
Sanding, Carpeting, and Reinstalling to go...
My Babies
Correct me if im wrong but wouldnt that foam grab the cone and cause it to hold there....??
no theres fiberglass under the foam, then the foam, and prob going to put more fiberglass over the foam.
the goldish carpet that on the pictures above is now gone, im going to put new black carpet over all of it once im done with the fiberglass
My Babies
my point of view:
its gonna sound like shit
subs look weak
infinate baffle FTL in ur regaurd
you shoulda just taken ur time and fiberglassed them in. just an IMO on everything
aslong as you like it, right on.
im taking out my passenger seat, battery is disconnected, going to unwire and take out the three amps, take out the 70+ lb box, then the platform so i can crimp 1 wire.
Almost as bad as those fegs that put those horns in their grills and roll down the street distorting the block....
1990 Jeep Cherokee 2 Dr.
Big-3 in 0g on Stock Alt.
Pioneer 6.5" and 5.25"s temp. until i can afford the new crescendos.
Pioneer 6000ub Reciever
NO amps at the moment. SA-15 on 1kw coming soon.
MSG Me for a free enclosure design!!
Flared port kits coming soon!!
my point of view:
subs look weak
there is fiberglass under the foam
theres two 10' r going to be hooked up to a 250watt amp for the mids. there are two 12's in the trunk with a 1000watt amp for everything else
Edited by Street
My Babies
my point of view:
subs look weak
hes glassing the foam and using the 10"s as midbass i think its going turn out rather well congrats
R.I.P!
(Nov-29-2009)
92 explorer
current build
mmmmmmmmmm cool whip
must be nice huh
  • Who's Online   0 Members, 0 Anonymous, 310 Guests (See full list)
