I read somewhere that instaling a second battery with a stock alternator cuases stress on the alternator is this true? Becuases i was thinking about putting a second battery in my truck but if it is going to cause stress i dont want to. & if it does cuase stress is it enough to do any harm?
1997 Chevy Cheyenne Single Cab
Pioneer DEH-3200UB
Two sets of Orion 6.5" Components In Each Door
AudioQue HDC3 15"
^^^ Its all For Sale!!!!! http://www.stevemeadedesigns.com/board/topic/99546-lots-to-sale-good-prices/ ^^^ AQ2200D
Wow, such a flexy beast(see what i did there lol)
I can see it causing stress if both of your batteries were discharged. I am sure it would have to work its ass off to recharge and to maintain the vehicles need for power. I added a second battery to my probe and noticed a difference right away in how loud it was.
Waiting for the experts to chime in.
Warm Regards,
Dyno Brian
1997 Ford Probe
|Sony Head Unit|Alpine V12 AccuClass-D MRD M1000 Amplifier|4 RE AUDIO SRX12D4 12's|Mids and Highs coming soon!|
|1998 Mustang GT Twin Turbo|1986 Mustang GT Single Turbo|1996 Mustang Mystic Cobra N20|1995 Mustang Cobra 5,000 miles|
2002 ZO6
each battery you add needs about 10 amps extra just to float it. the issue comes in where you drain that battery down (too much draw, not enough amps from alt) and the alt works double hard to charge both batteries and play the system and keep the car working.
H.O. alt FIRST
batteries SECOND
caps if you compete in sq and need to smooth out some ripples, otherwise their useless
Team DC
H.O. alt FIRST
batteries SECOND
Damn alt first? cuz im a broke ass mofo. and wtf im only running 250 watts and my voltage drops like no other at sometimes cand someone explain that?
Pioneer DEH-3200UB
AudioQue HDC3 15"
big 3
R.I.P!
(Nov-29-2009)
92 explorer
current build
Turn your gain and bass boost down?
Derp.
gain way too high in order to make it seem louder off of 250 watts? cuz that makes no sense, I had a T-1000-1bd on my sub and i only dropped .3 volts
250watts shouldnt make any difference to your vehicle
check all your settings and connections.
and yes an alt fixes the problem, not covering the symptoms
Team DC
250w? do the big 3. And your alt could already be on the way out.
Go to a wrecking yard and grab a second alt for cheap. Put it in place of the AC if you have it. If not slap together a bracket.
Hammerdown... 1%
  • Who's Online   0 Members, 0 Anonymous, 9650 Guests (See full list)
