What are some good ways to secure your audio in your car besides from the basics like alarms?
I read somewhere that using different kinds of screw heads is a good idea, from just using the phillips and flathead screws?? And what are some ways that a could bolt down my box and amp to the trunk or would that be kind of pointless because you could just unscrew/unbolt it?
Also could you guys give me some tips on what you guys do to protect your stuff?
Edited by JordanSchumaker
I usually hire this guy to watch over my car.
But for real. Of course most thieves can get the things you try to protect. The point is to try and slow him down. He doesn't want to do it all night, and a lot of the time ends up damaging your equipment. An alarm is key in slowing him down, along with a frustrating long dis assembly of everything inside.
Edited by finkster
Eclipse cd7000
Slowing him down makes a lot of sense because i guess you cant stop a theif if he really wants something.
I have these to mount the sub and amp and batt hold downs. Burglars don't usually have the right heads to remove these. I also spend extra time designing my system to look completely stock.
My hatch also takes 2 people to open, but thats fuckin annoying... :pardon:
Do you just hold them down with a metal bar?
Do you just hold the subs and amp down with a metal bar or something else?
when I mounted my amps to my van, I used bolts with tightining washers behind and it has two bolts, that way when they start to turn, if they have the right size bolt, most burglars don't carry a full on bolt set, then it will stop once you turn it so far :D I will be out there withing 1 bolt being started, that's my deterrent :P
2006 Mazda3 Hatchback Black 5 Spd Manual
Pioneer 4300DVD
2 Sundown SA-12 (34hz Tune, 3.22 cubes, 14.5 inches per cube, Triple Baffle)
Kicker 10ZX2500.1 (2845 RMS) Sub Amp
Kicker 11ZX650.4 (705 RMS) Mid Amp -- (3 Amps)
Kicker KQ3 Active Crossover
Kicker KQ30 Equalizer
Kicker 09QS60.2 Components (Woven Carbon Cones)
Kicker 09QS65.2 Components (Woven Carbon Cones) - (3 Sets)
2/0 Gauge Electron Beam Technologies (3 Runs, 2 +, 1 -)
1/0 Gauge KNU Kollasal Flex (1 Run for -)
300 Ft Kicker X-Series 16 Gauge Speaker Wire
XS Power D3400 (Rear)
XS Power D3100 (Front)
Singer Externally Regulated Alternator (Being Built)
+ The Love for Car Audio and BASS <3
UBL Build Log <------- Click Here-------> Normal Build Log (For Comments)
