Ford302Redneck Posted February 7, 2011 Report Posted February 7, 2011 Just cause it has two inputs doesn't mean its two amps.. Yes, each sub parallel is to .5ohms. Then parallel that and its at .25ohms. Quote
David711 Posted February 7, 2011 Report Posted February 7, 2011 The d5000 are stable at 1ohm by orion but you can play then at .5 without worrying as long as you don't have low voltage. The amp is not 2 amps strapped though. Mine have ran .5 with no problem at all Quote "WHOEVER SAID MONEY CAN'T BUY HAPPINESS MUST OF BEEN BROKE"
Ford302Redneck Posted February 7, 2011 Report Posted February 7, 2011 He has it wired to .25ohms though. As I assume, the output terminals are internally bridged like most are. Quote
chubalicious Posted February 8, 2011 Report Posted February 8, 2011 dont worry bro i did the same thing running my subs at .25 ohms. My system slammed but my amp kept cutting out. dc audio sent me a wiring diagram for running dual 1 ohm subs at a safe 1 ohm load Quote
mxman38 Posted February 8, 2011 Author Report Posted February 8, 2011 yeah, i going to wire them at 1 ohm tomorrow and see if its a significant difference in output... but if it is ill just go back to .25... Its worked strong so far... ill just have to watch my voltage. Quote
