Ok I have an eclipse 5030 and I was automaticaly going to adjust with a mic the time alignment. Well as it was sending pings I noticed rear speakers never sent a signal. I also have the SS 500.4. So I went to adjust fader and rear does not have any sound but when I put fader to 0 I have sound front and back. So what am I doing wrong
SONY XAV-701HD
RF power 400.4 RF power 1000bd
3 Sundown x8's d2
2004 f150 single cab
2 sets of components MB quart 6.5 onx (2 tweets 2 6.5 perdoor)
stock batt up fron
BIG 3
http://www.stevemead...-vid-pg-11-922/
http://www.youtube.c.../TheBigmescan74
Also has 3 outputs on radio F R SUB. also when I go to rear fader the sub plays. And nothing else.but the fader for sub is at 0
SONY XAV-701HD
3 Sundown x8's d2
stock batt up fron
BIG 3
Are you sure your amp is in 4 channel mode? Maybe the switch on it is set to 2 channel mode, if so it will only use the front inputs.
My Saab 9000 build
1993 Saab 9000 Aero 5spd
Just Say No To Rear Speakers
Just Say No To CCA Wire
Real Men Drive Stick
Its on 4 and if it was on 2 the rears wouldn't play at all correct
Try switching the front and rear inputs on the amp, then adjust the fader again. If you adjust it forward and no sound, then you know it's the amp. If so, it may have a bad switch for it's 4 channel - 2 channel mode.
My Saab 9000 build
I've done all that before so I know all four are working. But ill try again. That's what's confusing me because they all playin I can adjust x-over front back and rear from HU.
SONY XAV-701HD
3 Sundown x8's d2
stock batt up fron
BIG 3
